#76
#77
| From a thread over at SA, stubled on this Flickr page http://www.flickr.com/photos/*******seaclub/3245564861/ Nice looking bi-rig 'Happy Feet' |
#78
| Tandem rig and unique hydrofoil approach Quote:
http://www.youtube.com/watch?v=ZggxS...eature=related Happy Feet not only is a pioneer with the biplane aka tandem righ, but it also has a unique hydrofoil system on a pod. Instead of trying to lift the whole boat, just the windward float is out of the water when the foils lift the boat. Looks a lot more controllable that the usual, in which the whole boat is lifted out of the water. |
#79
| I have enjoyed reading all the arguments and theories for multi masted multihulls, but I can only quote from real life experience. In our multihull racing fleet we have a largish Catamaran with very efficient hulls. It has a schooner rig with two same height masts, and two same area fully battened mainsails. No Jibs or spinnakers. It is fast on a reach. average to windward, slow downwind and SLOoooow to tack. Give me a sloop rig any day. I'll tell you why in a later post. (Breakfast calling). |
#80
| In 1981 three of us sailed from Sydney to Lord Howe island in a sloop rigged Spindrift 45 catamaran. It had been built by the skipper as a very comfortable and easily handled Cruising boat. We left Sydney heads under main and Genoa and auto pilot. Light fitful winds limited our average speed to 6kts for the first 18hrs. Then the wind started to rise. The Genoa was furled from the cockpit, and anticipating a south easterly buster, the skipper went forward and lashed the clew of the furled sail for safety's sake. THAT WAS THE LAST TIME ANYONE WENT ON DECK FOR THE REST OF THE VOYAGE.. The intent was to hoist a smaller jib, but the wind came up so quickly that that idea was shelved and we continued on under mainsail alone. The seas became very big and the wind hit 50 kts gusting 55. A reef was taken in the mainsail from the cockpit to reduce speed to around 11-12 kts for comfort sake. When the speed rose to 17-18 kts another reef was taken in. If we had been racing, the higher speeds would have been exciting---but we were cruising wern't we? We homed in on Lord Howes beacon, sailing on a close reach, still on auto pilot. We arrived warm and dry, having averaged 10.2 kts for the whole trip, beating the then racing record by a large margin. Handling the sloop rig was a breeze with suitable winches (not powered), and all sail controls from the covered cockpit. There is nothing wrong with a well laid out Sloop Rig. |
#81
| one mast is most efficient aerodynamically, but there is a case for a cutter rig on a cruiser. |
#82
Note the second line of my post #80. We could have hoisted a stormsail on our inner forestay, however it would have been an unpleasant and dangerous thing to do in those conditions. The boat balanced perfectly on the double reefed main, whilst on auto pilot in 50kt winds and 40 foot seas. As I said we were cruising, not racing. The effortless high average speed was just one of the bonuses of a big cruising Catamaran sloop. The KISS principle in action. ![]() |
#83
| So Oldsailer do you think running backs are prudent or just 2 swept back shrouds? |
#84
#85
| Other justifications for multi-mast Quote:
#86
Yes, I see the triplane concept as a way to keep the CoE low. It is difficult to reef a wing, especially if it is a hard one, so one method would be to remove one or two wings, which is something I would like to try, hopefully next year. Quote:
Well? Is it? I'm going to start a new thread with an idea for doing just that.
#87
The boat rigs in minutes and gives him a large potential when he wants to trim it for his on the water needs. Kellan has not set it up like this, yet, but the XCR can also be configured with a single rig that steps at a fairly typical location in the hull... without moving his leeboard for proper balance. I'm really happy with this boat and the versatility it offers for coastal adventure cruising. |
#88
“We had ten people in the syndicate paying £50 each and unofficial sponsorship from the BBC — because most of the materials came from a friend who was a set designer there. We ended up with a boat with five solid sails, arranged like a Venetian blind. The Clifton Flasher, we called it. We held the record for a couple of years.” i believe that this layout will be used one day with good effect. i see more than 5 blades, possibly with the rig being wider than the boat. reefing needs a bit of thought but since each blade would be relatively small, handling them might not be so tricky. plenty of low down grunt. i witnessed clifton flasher sailing at weymouth and it looked good. very good. ahead of its time. |
#89
| Clifton Flasher...and a few others http://books.google.com/books?id=tE0...age&q=&f=false http://content.yudu.com/A14dxe/Multi...sources/39.htm |
#90
| The AYRS index credits Chris Robilliard with the design; presumably that's the production designer I find using Google. Apparently it took part in the John Player world speed sailing record attempt in Portland harbour but I can’t find the date. It is pretty much what I mentioned in post #73 but it doesn’t use the “tailplane” stabilizer,. There’s a pic of that concept here http://www.harborwingtech.com/
| another way to dock a multi | yipster | Multihulls | 12 | 12-03-2007 09:49 PM |
| Getting Afloats' "racing" Sharpie Single-masted? | Dunhill_BKK | Wooden Boat Building and Restoration | 11 | 04-27-2006 11:44 PM |
| Hydrofoil assited sailing cats | Buildboats | Boat Design | 32 | 03-12-2006 10:03 PM |
| hydrofoil assisted sailing cats | Buildboats | Projects & Proposals | 0 | 03-06-2006 12:18 PM |
| 255' Three-Masted Steel Barkentine for sale | Yachting | Marketplace | 0 | 02-09-2005 10:35 PM |
