  #31
Old 01-08-2009, 04:44 PM
Rep: 593 Posts: 2,054
I've done a boat with a twin masted setup... a trimaran, and she is a really sweet machine for handling, as well as a good turn of speed. As mentioned, there are all sorts of reefing and boat balance options available to rig design of this type.
I liked it right away because it let me lower the COE quite a bit compared to a single, taller rig. This, in turn, gave me loads of options to design a set of very lightweight amas and lighter weight aka tubes. The masts, themselves, could then become self supporting, rather than further complicate the design with shrouds, stays and all the hard points to support same. It also removes the compression problems to a large degree, allowing for a lighter hull structure.
Overall, for the design of the XCR trimaran, the twin rigs and all that came with them, were a very favorable design strategy. I'm using the concept on several of my trimaran designs and plan to use this rig format on a cat, or two, in the very near future.
Video Clip here:
http://www.youtube.com/watch?v=2eEou...e=channel_page
Multi-masted sailing cats-xcr-beach-powell-07-w.jpg  Multi-masted sailing cats-black-beach-fremont-07-w.jpg
  #32
Old 01-08-2009, 08:27 PM
robherc robherc is offline
Designer/Hobbyist
Rep: 102 Posts: 433
Nice boat Chris...looks great in motion...pretty quick too. Good Work :-)
  #33
Old 01-08-2009, 11:34 PM
aka Terry Haines
Rep: 1682 Posts: 2,810
I notice the masts are in tandem, and they look identical. There is an advantage to having them the same, economy of scale, reduced spares, identical rigging.
Chris, what is the sail material?
Dances with Turkeys
  #34
Old 01-09-2009, 08:24 AM
All the above, AK.
Beyond those important issues, I also use the same sail on about a dozen other designs. If the homebuilder chooses to build another boat from my portfolio, then there is a good chance that he will not have to buy another complete rig. This process enhances the savings and makes the sail inventory that much easier to manage.
The sails are built in Dacron. This set was made by Stuart Hopkins who goes by the loft name of Dabbler Sails. http://www.dabblersails.com/index.html
Stuart makes terrific sails that are beautifully made with a high degree of attention to detail.
  #35
Old 01-09-2009, 09:46 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
I have some objections to that rig. No place to put a fish in I can see you leave (tough choice ?) your buddy (or wife ) to take the fish out. If the bar is closed you go back for either.
Regards
Fanie
Water ! Just gimme water !
  #36
Old 01-09-2009, 10:20 AM
Designer/Hobbyist
Rep: 102 Posts: 433
Hmm...that could be easily enough to remedy...just design a fish/bait well to hang on the ama arms (better make that two) on either side (to keep things balanced). Then they're removable when you're looking for all-out performance, and easily re-installable when you want to get some fishing in
  #37
Old 01-09-2009, 10:28 AM
Fanie's Avatar
Fanie
He he... I can see you Texans aren't used to fish. You hang it somewhere and guaranteed the biggest shark in that area will make it his business to relieve you of it. It's a bit like our residential living here in SA
Chris, those sails, one in each ama's, could free some hull space up... Any drawbacks to using it like that ?
Regards
Fanie
  #38
Old 01-09-2009, 10:33 AM
Designer/Hobbyist
Rep: 102 Posts: 433
I didn't say to make the bins clear...I doubt the shark'll be able to sense them inside an opaque tub with sonar (though I guess that still leaves dolphins as a concern )
Of course, with my luck, right about the time I put a trophy fish in one of 'em...I'd get hit by a whale or somethin' ... knock the bin into the water, and send me home with no fish except for the ones in my story...rofl
  #39
Old 01-09-2009, 10:59 AM
Fanie's Avatar
Fanie
Sounds like the normal kind of thing to happen. Whales are nothing, it's those giant squids that worries me.
Regards
Fanie
  #40
Old 01-10-2009, 10:06 AM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
multi-masted multihulls
I was looking for some other items on my computer and ran across these two photos
Multi-masted sailing cats-tamamoanacat.jpg  Multi-masted sailing cats-newicks-white-wings.jpg
  #41
Old 01-10-2009, 11:22 PM
oldsailor7 oldsailor7 is offline
Rep: 253 Posts: 1,063
Brian.
The only reason I can think of as an advantage on that Trimaran is the fact that the mizzen sail enables the boat to balance, given the very forward position of the mainmast.
There is nothing wrong with that.
It enables the accomodations to be expansive in the middle of the boat, and trimming of the helm is easily done by adjusting the mizzen.
As a result it is probably a very nice cruising boat.
If they really wanted "Performance" as well, all they have to do is put a furling jib on a bowsprit.
  #42
Old 01-11-2009, 12:23 AM
aka Terry Haines
Oldsailor, you mentioned balance first and then went on to suggest adding a jib.
That prompted me to wonder how the jib would effect the balance. Does the CE remain more or less in the same place when the jib is raised (I haven't sailed with a jib so I never had the chance to find out for myself)? Or does it move forward as seems intuitive?
I ask the question as, from reading another thread, there seems to be some uncertainty when establishing the effective CE of a rig; it seems clear that it has only a loose connection to the center of area.
Dances with Turkeys
  #43
Old 01-11-2009, 12:51 AM
Designer/Hobbyist
Rep: 102 Posts: 433
To get a "true" CE you'd have to figure the area of each sail, the center of area of each sail, and the actual effort (i.e. beam windage) being exerted on each sail. Figure these all together & you can find the CE which, consequently, can and WILL move about the boat a bit at different angles of trim.
With that in mind, if you fly a jib that is fairly small, relative to the main/mizzen, and you fly it with a bit more luff (did I get the right word there?), then it'd make a very minimal difference to your CE, while still giving you a bit more forward power, at least when reaching/running. A genoa would DEFINITELY unbalance that sailplan though...lol
  #44
Old 01-11-2009, 12:53 AM
Designer/Hobbyist
Rep: 102 Posts: 433
So I guess it really boils down to how tightly you sheet in the Jib. Tight sheet = moves CE fore; loose sheet = moves CE aft.
  #45
Old 01-11-2009, 03:09 AM
jamez jamez is offline
Rep: 184 Posts: 263
The sail plans for the Newick designed Spark and White Wings (post 40) both show a wire-luffed headsail that can double as a mizzen staysail. White Wings has 2/3rds the displacement of an F36. The newick Lungstrom ketch rig is a no bones cruising rig but the way DN designs his boats they almost can't help but be quick. A sloop rigged Echo would probably be quicker than WW to windward but cruising down wind without extras I suspect there wouldn;t be much in it.
another way to dock a multi yipster Multihulls 12 12-03-2007 09:49 PM
Getting Afloats' "racing" Sharpie Single-masted? Dunhill_BKK Wooden Boat Building and Restoration 11 04-27-2006 11:44 PM
Hydrofoil assited sailing cats Buildboats Boat Design 32 03-12-2006 10:03 PM
hydrofoil assisted sailing cats Buildboats Projects & Proposals 0 03-06-2006 12:18 PM
255' Three-Masted Steel Barkentine for sale Yachting Marketplace 0 02-09-2005 10:35 PM
