Old 03-04-2009, 08:07 PM
Delaney Delaney is offline
Rep: 27 Posts: 16
Motorpod designs
What kind of motor pod designs are out there for adding center mount motor to something like a Jarcat J6?
I am also interested in adding a bit of flotational support in the back to give the boat a little more load carrying capacity. What I would really like to do is add a sponsoon that would only be immersed under a max load with the exception of the end where the motor would be as ofcourse that part would always be immersed. Is thus possible?
thanks
Old 03-04-2009, 08:53 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Hi Delaney,
I don't know Manie was here once (he's buildig a jarcat) and he mentioned a single outboard in the cabin. I suspect it has a bracket that folds up using sort of a scisors action, similar to attached. Sorry about the out of focus...
You could make the sponsoon above the waterline... maybe make it look like a hull feature.
Regards
Fanie
Water ! Just gimme water !
Old 03-22-2009, 02:53 AM
bill broome bill broome is offline
Rep: 48 Posts: 102
maybe the answer is to lower the level of the central 'tunnel' so that it's kissing the water in moderate loads, immersed under heavy loads. this is 'free' volume, except that it will be noisier when light.
i can't think why you'd want to, the j6 has a very fat water plane already.
Old 03-30-2009, 07:43 AM
Rep: 27 Posts: 16
Bill,
When you say the J 6 has a wide motor plane do you mean I should mount the motor on one hull? Otherwise I was under the impression that if I mounted in the center that I would need somekind of motor pod to make it function properly. Is this correct? I was thinking about powering it with a 9.9-15 hp motor and sailing it with a kite sail on the occasions when I want to sail.
Thanks,
Delaney
What about the old designs? big-boss Boat Design 26 04-28-2008 11:01 AM
Id like to see your designs hrspwr1 Powerboats 5 03-06-2008 12:34 PM
New designs are lame juiceclark Boat Design 42 02-13-2008 10:15 AM
Looking for designs ivansalasj Boat Design 3 06-06-2004 02:41 PM
Looking for different designs for boat Open Discussion: All Things Boats & Boating 3 10-23-2003 08:46 AM
