| Motor question Hey everyone, the normal motor on my Buccaneer 33 trimaran, a 30hp Tohatsu 2-stroke, decided it was going to refuse to start and then loose its leg oil... So until I get around to fixing it I'm down to using the only other outboard I have, an 8hp Tohatsu 2-stroke. What I'm wondering is if my little 8 has the power to push my boat. I only need it to do hull speed. Any help welcome, -Wolf |
| I'll bet she'll do 5 knots in still airs. -Tom |
| I'm just concerned about it's ability to motor for 30 miles. |
| Wot ? Much too much. On my 35footer (with a deplacement in cruising trim of 2m3) i have a 15Hp Mercury 2-stroke with a standardprop , that`s enough. The motor is in a vertical tunnel in the cockpit, can be lifted with a tackle. No ventilation. While sailing the tunnel is closed by a an overlapping alloy plate, screwed to the outboard`s fin. Simple and effective. I guess that 8Hp aren`t enough for your boat, but, it depends on cubic and prop. A 10Hp outboard with 250ccm and two cylinders should have enough torque to drive your boat. The motor needs a prop with little less than standard pitch. Before i bought my Mercury 15Hp 2-stroke with 34kg , i had yamaha 4-stroke of 50 kg . That motor gave only half a mile cruising speed more and consumed only half a liter less---but cost twice the money. The Yamaha4-stroke is only a good motor when you push it at half throttle, then it consumes about 2 litres per hour. It`s a motor who`s gear and props are designed for 26´waterline. The high thrust is only a nearly useless reserve for manouvering. u don`t use it while cruising. If u wanna push your boat to a hullspeeed of 7-8kn , with 3/4 throttle, then the motor consumes 3-3,5 litres, which is the same of a 2-stroke with 50% more nominal power that only costs the half . 2-stroke with volume--light and power is the better way ! pogo
__________________ Immer handflach Wasser unter`m Schwertschlitz ! |
| Yeah, the 30 is a bit or the "large" side for a motor, but it was the only motor we had at the time we got the trimaran. It's supposed to be on our 14' zodiac. The 8hp in question is off my late father's 35' racing cat, it managed to push that boat at about 7knots. I'm hoping for at least 6 with the tri. |
| Do it, there is nothing to loose, and if the prop is suitable, the tri will certainly do 6 knots with the 8hp.
| I assume your engine is at home It isn't on your engine bracket Richard Woods of Woods Designs www.sailingcatamarans.com |
Should be alright. ![]() |
| Thank you for all the input everyone. |
| I used a 1957 7 1/2 hp evinrude for a year or two including looong trips on my 37' Nicol. It would cruise at 5 + knots except in a headwind where the prop slip would increase with the wind velocity. Your boat should do even better as it is lighter though you may not get the fun of repairing antique motors a few hundred miles from home ![]() |
| Clark Craft's Jeckle9 motor question | volkswagen50 | Inboards | 5 | 02-01-2011 05:09 PM |
| Trimaran outboard motor question. | SpiritWolf15x | Multihulls | 15 | 06-15-2010 09:33 PM |
| volvo motor /stern drive question | tubbymann | Sterndrives | 6 | 08-06-2008 09:00 AM |
| Used Boat/Motor Question | stangfl | Outboards | 2 | 03-25-2008 03:16 PM |
| Motor Canoe Question | SaltOntheBrain | Boat Design | 9 | 03-11-2008 12:26 AM |
