  #31
Old 11-23-2016, 10:46 AM
cavalier mk2 cavalier mk2 is online now
Rep: 214 Posts: 1,990
Between the pop bottom and lifting hatch all those headroom bases get covered but sailing doesn't suffer. Maybe you could track it down to see if the buyer still wants it? Sometimes people get bored of a project.
  #32
Old 11-23-2016, 07:53 PM
guzzis3's Avatar
guzzis3 guzzis3 is offline
Rep: 42 Posts: 293
You mean the sango ? Yes maybe. It was on gumtree and I don't have the sellers details.
There is another way to get headroom in a sango. Make the optional bolt on coach roofs for the hulls taller. I don't know how Mr Woods would feel about it, but elf has 1.8 headroom and the roofs could mimic the profile of the cuddy.
  #33
Old 12-25-2016, 10:11 PM
guzzis3's Avatar
Rep: 42 Posts: 293
Goodness:
http://rogermann.org/puddlecat/desig...der-catamaran/
  #34
Old 12-26-2016, 02:50 AM
UpOnStands UpOnStands is offline
Rep: 16 Posts: 283
appears to be no side deck access to the bow?
over the top only?
  #35
Old 12-26-2016, 04:22 AM
Manfred.pech Manfred.pech is offline
Rep: 319 Posts: 482
over the top only?
  #36
Old 12-26-2016, 06:01 AM
Rep: 16 Posts: 283
nicely done
  #37
Old 12-26-2016, 09:49 PM
guzzis3's Avatar
Rep: 42 Posts: 293
As usual my opinion is worth what you paid for it, and here it is.
I had a J5. In my opinion the side decks are dangerous and your far better off without them.
The problem on mini bridgedeck cats like this is that the side decks are barely more than toe rails, or else they encroach on the cabin too much. They are too narrow for stanchions and in any sort of water the chances of you slipping and falling off are just huge.
In my opinion (again) your better off without them so there is no temptation. Going over the top on a boat like that is not hard provided it's designed with that in mind, and you take advantage of the cats large beam and large flat cabin top to make a safe move forward.
Again this is what they did with the little barrier and I think it was an improvement on the jarcat/red barron etc
Attached should be a photo of a little barrier. The trimaran I include because I am pretty sure I used to own the center hull of that boat. It was a modified tremolino, it's interesting what they did with it...
  #38
Old 12-29-2016, 03:09 AM
redreuben redreuben is offline
redreuben
Rep: 349 Posts: 1,461
Craig Schioning.
http://spiriteddesigns.com.au/seascape
  #39
Old 12-29-2016, 08:25 PM
guzzis3's Avatar
Rep: 42 Posts: 293
Hi,
Is there something in particular about seascape that your pointing out ?
He has the stowaway 7.5 aswell.
http://spiriteddesigns.com.au/stowaway7_5
I know this isn't very nice but I have to say I properly hate those boats. I got the study plans for the 7.5 and it's a truly awful design imo. Deep V hulls, overly stylised topside. I really don't like anything about them. As usual just my opinion...
  #40
Old 12-30-2016, 03:24 AM
redreuben
Nope, throwing it out there.
  #41
Old 12-30-2016, 06:09 PM
guzzis3's Avatar
Rep: 42 Posts: 293
You must be strong
  #42
Old 01-06-2017, 12:11 AM
VadimGo VadimGo is offline
Rep: 10 Posts: 15
Yep,
another one of those.
Transportable, or even better, trailerable, accommodations for a couple or a small family, head/shower... and easy and fast on the water.
Pls, keep us informed, when you find it, I would love upgrade from the SW 24.
  #43
Old 01-08-2017, 06:23 PM
guzzis3's Avatar
Rep: 42 Posts: 293
I never said anything about fast.
The SW is a nice enough boat but it is what it is. You might like to take a close look at Mr Woods eagle:
http://sailingcatamarans.com/index.p...t/455-eagle-24
While drawn in ply it can be built in chined foam. Similar size package to your seawind but offering a lot more comfort, accommodations and it'll certainly be a lot drier.
I don't recall sailing a seawind 24 but I would think performance might be similar.
  #44
Old 01-08-2017, 11:00 PM
redreuben
Just thinking aloud here but one way of getting more headroom in small boats is to go deeper rather than higher, Wharrams do this and to a certain extent Horstmans, this means the ends are usually submerged and wetted surface goes up a lot but windage is kept down. Swings and roundabouts again.
  #45
Old 01-09-2017, 02:02 AM
Rep: 16 Posts: 283
yes, but the relatively low speeds means that wetted area may not be so critical?
Modern Pirates Mikthestik All Things Boats & Boating 47 06-08-2016
05:37 PM
Hirondelle remake? Lolodoc Multihulls 11 09-06-2013
05:48 PM
Modern paddlewheels Guest Boat Design 137 06-17-2013
11:30 AM
Modern 350 Marinizing LMannyR DIY Marinizing 45 09-24-2010
07:14 PM
Modern square-rigger? ekiqa Sailboats 2 06-10-2007
09:57 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
