#226
| In calm water (like a dam) calculated motor should give at least 10 knots you need 3x that for the actual boat at least so if calculations show 5hp buy a 15hp fourstroke 30% lighter on fuel what i found personally
__________________ Bye bye Folks - off to see the world ~~~/)~~~ :) Compulsive Neurotic Manic Depressive, but basically happy :) http://compaxboats.wordpress.com/ http://www.boatdesign.net/forums/boa...ser-27869.html |
#227
| Thank you for having my designs high on your list. You cannot go wrong with a high thrust 9.9hp Yamaha on a 9m catamaran. We even had one on our 34ft Romany and could cruise at 5.5knots under power. But that boat was at the top end of size for a single engine. However I also used one on my 28ft Gypsy and my 30ft Sagitta. It worked great on those smaller designs. You want a minimum cruising cat, so you will have to accept that sometimes you cannot sail or motor as fast as you'd like. I think you will regret not having standing headroom in at least the hulls. If nothing else it means the freeboard is low so the boat is wet to sail, and there is also a greater risk of bridgedeck slamming. Both of these lead to discomfort at best. I assume you want to enjoy your cruising?? I think it unlikely that you will find any professional designer willing to "check over" your own design. I wouldn't do it. For two reasons: 1) it makes me liable for any of your design faults. 2) It would take me so long it would be cheaper for you to buy one of my stock designs. You do have to think about insurance, certification (if needed) and resale value when designing your own boat. Hope that helps Richard Woods of Woods Designs www.sailingcatamarans.com |
#228
__________________ Matt Marsh M. B. Marsh Design The Marsh Fleet: Small-craft cruising on the waterways of Ontario and beyond |
#229
| Thanks guys - designing is a fascinating process and is teaching me exactly how much does go into creating a finished boat!!! Even if i dont design one - i like learning the how and why of things and while complex math isn't really my thing, it is teaching me a lot about boats, which will allow me to make informed decisions in the future. And all you people out there giving time and info on this (and other) forums - thank you very much!!! Speed not so much the issue as saftey and being able to get out of trouble if needed. Freeboard at 1m to 1m10 / deck 1m up and beams 90cm - more than 10% of length! Freeboard is low.... but can be upped along with headroom. Hulls are narrow - hull beam 70cm at wl =12.85 and flared going up to 1.2m. 9m loa - 7.5m at wl. Beam 5.4m = 60%. I like double enders...... and rounded - quarter circle. Headroom idea is that in ok weather or anchoured i will have full headroom. But am at the beginning of this all and no doubt it will develop and change lots as i go....... And simplicity/low cost are more complex than i would have thought.... |
#230
| I have never had any problems with the Yamaha outboards except the time I was hit by lightning. I have had 5 of them, starting in 1985. So no need to worry unduly about spares A good starting point when designing anything is "use your eyes and plagiarize" Based on you initial requirements, from months ago, a boat that would suit you would be my 28ft Gypsy. That is a hugely successful boat with a couple of Pacific crossings to its credit, plus many offshore trips. So I would start with that as a baseline and modify it to suit your own needs Good luck Richard Woods of Woods Designs www.sailingcatamarans.com |
#231
| I do like the gypsy. The wife wants to know what being hit by lightning was like? |
#232
![]() If it's hits by lightning you should consider a different religion maybe. If outboards, give the poor things oil, they'll last longer ![]() Quote:
#233
| I was hit by lightning once. I was on the phone with a customer when I was hit. I just saw a flash and when I 'woke up' I was lying in the chair on my back with the phone on my chest. No clue how long I was out. That's why I suggested to Richard consider changing religion. I now believe when there's heavy weather, stay away from wired telephones ![]()
#234
| You can read about my lightning experience on the Articles pages of my website Richard Woods of Woods Designs www.sailingcatamarans.com |
#235
| Yammie Here is a good talk by a sailor from Australia who circumnavigated using Yamaha 9.9s. His boat is a 32 footer stretched a little. As for finding spares, Chris (the featured sailor) says it is much easier to find outboard spares and petrol than diesel spares and diesel. http://www.seawindcats.com/index.pl?page=584 cheers Phil |
#236
| Rush is another Australian circumnavigating catamaran (33ft Crowther) that used a single 9.9 Yamaha. You are right about the oil. The first high thrust models had a fail safe design flaw, later rectified. You had to change the oil every 50 hours, not because there was less of it, but because the viscosity changed That doesn't seem to be a problem now Richard Woods of Woods Designs www.sailingcatamarans.com |
#237
| I found the ultralight nylon/plastic prop to be good for a extra 1/2 knot on the Yamaha high thrust we use on my Vagabond mk2. We can go over 7 knots flat out when light but usually cruise at 5 1/2 to 6 for economy. I ran the formulas and with that prop there is almost no slip which was a new one for me. The best thing about them is they are easy to work on if you ever have to. It will still make good headway into a rising wind. |
#238
| I better send in this correction before the nitpickers come after me. The ultra light prop was on our first 9.9, We haven't gotten around to reinstalling it since installing a 25" shaft version which is a neat option to look for. We kept the same prop depth but raised the motor height to keep the power head out of the spray. I've run outboards without the Yamaha's reduction gear but the prop is always functioning with lots of slip and headwinds slow the boat down more. If you can't find a 9.9 high thrust you should look at bigger 4 strokes. The gas used in a 2 stroke will weigh the boat down ! |
#239
There is a great pic of Samnz B24 on a weekend cruise with two couples on board, on the B24 thread. We've done coastal cruising with three on board. The loo is best positioned under the head of the forward berth. And small is less expensive. ![]() |
#240
Rob |
| S&S34 Cruising speeds & equipment | Steve Pereira | Sailboats | 3 | 12-11-2008 01:36 AM |
| Minimum size for ride comfort? | SamM1234 | Boat Design | 43 | 01-30-2008 04:27 PM |
| minimum size steel? | zeljkomrsic | Metal Boat Building | 10 | 10-04-2006 04:05 PM |
| Minimum wire size | arjan | Electrical Systems | 9 | 02-19-2005 10:49 PM |
| Typical cruising cat Cp etc. | maxhroom | Boat Design | 0 | 12-07-2004 09:56 AM |
