| Midship Construction Drawing I am Doing a Trimaran for my project & i need to know do i have do draw 3 different midship drawing or i should draw the midship only for the middle hull????????????????????? plz if any one know then help me. |
| You gotto draw what ever drawings your project and/or yard requires to make important details clear.. |
| I think we need a separate forum for student project questions. The midship construction drawing needs to show how the entire boat is built. Presumably she's symmetrical about the centerline so you need to show half the center hull (Vaka) in a tri, plus the cross beam (Aka), plus the Ama, (outer hull). How all these pieces connect together is very important to the structure....there's a long thread on cross beams here somewhere. Good luck.
| construction drawing mirror dingy | sass | Boat Design | 6 | 10-16-2009 03:59 PM |
| Midship interceptor | HJS | Boat Design | 25 | 12-16-2008 05:19 AM |
| shell expansion and midship section drawing in workshop | pavel915 | Software | 5 | 02-27-2007 02:27 AM |
| midship coefficient - Cm | mcollins07 | Boat Design | 9 | 01-26-2007 03:45 AM |
| i/o midship jackshaft systems | tuttlec | Propulsion | 1 | 11-10-2005 10:50 PM |
