Old 06-13-2009, 02:57 PM
oscarvan's Avatar
oscarvan oscarvan is offline
Rep: 10 Posts: 18
Mast Raising
I am getting closer....... now working on a mast raising setup. On the trailer, ama's folded. It needs two things, a fulcrum and stabilization. Because of the mast foot design it needs to come up from forward to aft. There's a nice support on the post on the trailer that will support it laying clear of the bow pulpit, with the bottom of the mast in the foot, hinge pin installed. (It gets removed afterwards as it is a pivoting mast).
I am using the boom as a fulcrum, with the halyard to the end and the main sheet as purchase. It needs side to side stabilization. Also the mast on it's way up needs side to side stabilization. The key is that these stabilizing lines (steel wires with thimbles and snap shackles) attach to a point in line and in plane square to the pivot at the bottom of the mast. This ensures that the required length stays the same on the way up.
Now, the problem is that this point is well above the cabin top, and that mounting anything there, like a chain plate would require drilling holes, and more importantly, would leave a trip or stabbing hazard on deck. So, I came up with the idea to have a steel ring there, which is held by two wire lines that go to existing mounting points on the floats.
The way I see this, these multiple triangles keep each other in tension all the way up. It would take seconds to install and remove. Once the mast is up, the forward shrouds tension, as well as the headstay. The halyard/boom/sheet would tie it down until I get the running backs on and voila...... I think this should work, unless I'm missing something. Any comments?
Out there, alone, there is only truth.
Old 06-14-2009, 12:06 AM
bill broome bill broome is offline
Rep: 48 Posts: 101
have you considered welding/fabricating a cross bar to the foot of the mast, creating a transverse pivot line? no erection stays needed. big time saver, on a trailer sailer.
Old 06-14-2009, 09:37 PM
oscarvan's Avatar
Rep: 10 Posts: 18
I have considered that. The mast is a rotating mast......(while sailing). That would get interesting, it would have to be removable, and then you're back to setup break down. These two "spiders" attach to existing rings/eyes etc.
Old 06-14-2009, 10:54 PM
bruceb bruceb is offline
Rep: 153 Posts: 564
raise the mast
Oscarvan, I built several similar set-ups for boats up to 25', and they all worked just fine. I even had a couple boats set up to do it in the water, although they took some extra effort. The weight of the mast extending past the fulcrum is usually the limiting factor, pinning the step can take quite a bit of strength. The main sheet might have to be extra long, or a different block and line used, I found a 4 to 1 was plenty on 50-70lbs masts. Bruce
Raising the Sheer Dane Allen Boat Design 6 07-30-2008 01:42 PM
Raising Kids On A Boat timgoz Open Discussion: All Things Boats & Boating 43 03-14-2008 07:25 PM
Raising the transom rwstoney Fiberglass and Composite Boat Building 3 12-17-2007 08:18 AM
raising my top and mast john a roberts Sailboats 2 07-24-2006 07:01 AM
Partially raising a dinghy centerboard amolitor Sailboats 12 02-18-2005 04:37 PM
