Old 09-15-2010, 11:01 PM
taezow taezow is offline
Rep: 10 Posts: 40
mast
Do masts for trimarans have to be stronger than the same length mast for a mono?
In other words, Can I buy a 30 ft mast off a mono hull to replace the 30 ft mast on my tri?
thanks
Old 09-15-2010, 11:28 PM
Richard Woods's Avatar
Richard Woods Richard Woods is offline
Woods Designs
Rep: 976 Posts: 691
Quick answer is no.
The righting moment on a trimaran is much higher (basically you can carry full sail for longer and the boat does not heel in gusts)
You'd be better to look for a mast from a 35fter
www.sailingcatamarans.com
Old 09-15-2010, 11:37 PM
Alik's Avatar
Alik Alik is offline
Rep: 1070 Posts: 2,036
On an mono, mast is usually designed using RM30 as design load, i.e. righting moment at 30 degrees heel, with safety factors of 2...3.
On a multi, huge righting moment RM at 10-20 degrees would result much higer loads, but design practice is to reduce safety factors so the mast is not oversized.
I would suggest to consult mast supplier on the issue.
Old 09-16-2010, 04:44 AM
Rep: 3125 Posts: 9,403
It all depends on the section you need for your boat. Yes, it's possible that a 30' mono has the same section mast as you need, but again it's the extrusion section that's going to be the key here, not if it's off a mono or not. If you know what the section of you mast is supposed to be, then this is what you'll compare. Since you've asked, it's likely you don't know the section, so calling up Dwyer Masts or some other outfit would be the best advise you could get.
Old 09-16-2010, 03:58 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Also, there are few 30 foot monohull sailboats with the same mast scantlings. A 400 sq ft sailplan on one 6000 lb 30 footer uses a smaller mast section than a 20,000 lb 30 footer with 900 sq ft of sail.
As PAR said, the section is the key variable, which might be the mizzen from a 50 foot ketch or off a 40 ft schooner, etc..
Old 09-16-2010, 04:27 PM
ThomD ThomD is offline
Rep: 98 Posts: 375
The staying base for a trimaran is much wider than on a mono, allowing you to support the mast properly with less tension.
Old 09-16-2010, 05:51 PM
Rep: 10 Posts: 40
Ok,
My mast looks stout enough to be on a 35' boat. Looks way too big for my 25' tri. But that is what I need ;]
I'll get over it looking to big.
Thanks
Old 09-16-2010, 07:00 PM
It would be much easier if you just told us what you have and what you need. Taking a guess at what you need is a fairly sure fire way, of insuring your rig will be inadequate.
Old 09-16-2010, 08:24 PM
Rep: 10 Posts: 40
What I have is just right. It just looked way to big for my boat, and it is heavy to raise.
I'm sure it is good, it has been on the boat for 20 years. It looked to me like a over kill, but now I know it is not,
thank you
rotating freestanding wing mast section and mast bend Timothy Sailboats 6 06-25-2010 11:53 AM
How to drive a mast down the road and lower a mast yachtwork Boat Design 0 12-18-2009 11:12 PM
mast step and mast heel corrosion urisvan Sailboats 10 11-23-2009 02:22 PM
need help with mast sailboatman Sailboats 9 06-27-2008 09:40 PM
mast design-how do you go upon calculating the effect of the sail on the mast??? airturb Sailboats 34 02-21-2005 09:55 AM
