Old 09-06-2007, 08:27 PM
holly holly is offline
Rep: 10 Posts: 12
Which Lumber?
Hello again,
I would like to get opinions on lumber for stringers for a 22' catamaran.
I can get either Cypress or Yellow Pine the corrrect size and for the same price. ( .65 a foot).
So let's see who has knowledge of lumber for stringers!
Thanks for all your help. I do appreciate it!
Holly
Old 09-06-2007, 10:04 PM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Take a look here:
http://www.boatdesign.net/wiki/Mater...t_Construction
Regards, Terry King ...On the Red Sea at KAUST
Old 09-06-2007, 10:24 PM
Rep: 10 Posts: 12
Thanks Terry
You sound like you are having a nice cruise!
Fairwinds my friend, Holly N4KXG
Old 09-07-2007, 12:11 AM
alan white's Avatar
Rep: 1168 Posts: 3,269
Either wood is just perfect. By stringers, I assume you mean chine logs and other such things, since a cat of that size wouldn't need longitudinal framing parts between corners. Perhaps the yellow pine will hold fasteners better, which is significant if you are using fasteners.
No matter what you use for stringers, you should use rot-resistant woods. Yellow pine and cypress are therefore both good choices. 65 cents a foot sounds very cheap, but you must be talking about ready-made pieces of the dimension required (linear feet) rather than board feet. Maybe the pieces are 3/4" x 1 1/2", which would be about the dimension of a stringer for such a boat.
Hand pick the pieces for straight grain. I see a lot of folks framing boats with wild-grained wood, and it does make a big difference in strength to choose your wood carefully. What often causes a stress break in a piece of wood can be blamed entirely on the run of the grain.
Alan
Old 09-07-2007, 02:17 PM
Rep: 10 Posts: 12
Thank-you Alan, very good information from the forum as usual!
Yes, the stringers will be 7/16X 1 1/4" for the two 22' hulls.
The shop will make the right size from their stock of yellow pine or cypress for me. I may as well have them make my frames there as well, 3/4"x 1 3/4".
Have a great day..holly
Best domestic lumber for boats? putz Materials 11 07-08-2007 03:19 PM
Composite Lumber, 3 questions ??? Deeman Boat Design 1 07-06-2006 04:53 AM
Drying Lumber coh boat Wooden Boat Building and Restoration 2 02-01-2006 12:26 AM
Lumber Supplier medphys3 Materials 2 07-11-2005 03:03 PM
plastic lumber fritzdfk Materials 2 03-20-2005 08:54 AM
