#496
Warren had this information posted on his site for a while - you just never bothered to read the information - preferring to criticise without the facts. The motor is not 3kW as you indicate - the numbers are there in the specs - which again it seems you did not read. At 48V and 200 amps peak the rating is 9.6kW with a maximum continuous load of 4.8kW. Interesting that you use the power of the outboard motor at its peak - whereas it is very rarely operated at peak rpm. There is another consideration. There are gearbox losses in the outboard, which need to be considered and the torque characteristics of an outboard mean that the prop is comparatively underpowered compared to that which can be used with a high torque electric motor. All of these factors are the reason for the favourable comparison and perhaps why Cunard power a cruise liner with electric motors! I agree that at this stage electric propulsion is not fully developed but Lagoon are producing an electric motor drive catamaran and other companies are evaluating the technology. Warren's point seemed to be that if you plan to sail mainly offshore and only use your motors in entering and leaving port then electric motors have attractions. |
#497
| Sailing with no Engines For Alik's benefit - perhaps he should read: http://landlpardey.com/ Lin and Larry continue to sail around the world without auxiliary power - not the choice of most but still possible even today :-) |
#498
![]() Quote:
Do You know why this model of motor is '3000'? Because it is 3kW=3000W motor! For Your info, continuous RPM for outboard motor is about 80% of max RPM. It is very close to peak, and for some engines it is peak of power. See power/RPM curves on manufacturers' sites. Quote:
#499
| Just sample: https://secure.suzuki.com/marine/_m/...s/df15-9.9.pdf Look where is the peak of power at page 3 - it is not on max RPM. Also, outboard engines are rated by HP at propeller shaft, so gearbox losses are already subtracted from the specs. |
#500
| Hello Alik, I just learned something from you. I did not know that outboard engines rated HP that way. I am used to flywheel HP and shaft or ship hp. SO ARE OUTBOARDS SHAFT or ship hp? tHANKS MUCH, Stan PS I usually multiply flywheel or brake HP by .07 to get Ship HP. Am I right??? |
#501
| Hi rasorinc, Pls see this sample: http://www.honda-marine.com/modelDet...odelGroup=BF20 Rating is given for propeller shaft. |
#502
| Thank you Alik, I did not know that but I'm only 67 and still learning. Stan |
#503
| Electric Motor versus Diesel |
#504
| wait Also Concerned post again because you are going a little off of this thread with those electrical considerations....then RB can sell another boat.... |
#505
| Quote: It is common knowledge that electrical motor gives more flexibility to choose operational mode of vessel because fixed pitch propeller is matching only one point at diesel/gasoline engine power curve. Diesel-electrical propulsion with generators and electrical motors is used for floating cranes, tugs, some trawlers where high propulsive manueverability is required. BUT this does not mean that electrical motor is more efficient, and this does not mean that 3kW motor can give same performance as 20-25HP diesel/outboard. Try Google again! Try to find a curve showing how the engine matches the propeller, then You can see want happens. |
#506
| series wound dc motors by... Also Concerned |
#507
![]() Also once You have burned the engine or any electronics - can not fix it in the sea, can not even get a service in marina - there is no service, only from supplier Honda, Yanaha or Suzuki outboard one can service in any marina. |
#508
Lagoon actually uses either 10kW motors or 40hp diesels - but I guess that their designers and engineers are not as knowledgeable as you. By the way I am not Warren - again you make assumptions without reviewing the facts - which clearly demonstrates why Russians have a stereotype reputation as being pig-headed and arrogant - as well as rude. |
#509
| i found a photo of Also Concerned Cleaning the computer what i found just right now ? A photo of Also Concerned , the day of the delivery of his boat !!! and was an electric powered catamaran ! I don't know the power exactly , as we did not install the motors , but was running in calm waters at about 6 knts . |
#510
Outboard's power is rated at about 80% RPM that corresponds to continous power. You can drive the boat at this RPM for considerable time. Peak power of electrical motor is not continous power! You can not drive motor at this power excerpt for few seconds. Recommended power is 3kW - this is basis for any calculations. Don't tell me about prop size/torque/power - You are absolute ZERO in these matters, You are not marine engineer to argue about that. Have You ever did propeller calculations Yourself? I know the answer - NO. I don't care what is Lagoon doing, woud like to see the feedback (not promotional test drive from magazine) on real things. |
| Superyacht Catamarans | Craig C | Multihulls | 0 | 11-19-2006 06:45 AM |
| Low power tunnel, low speed drive | robrohdeszudy | Propulsion | 9 | 12-23-2004 04:09 PM |
| Catamarans: 2004 Sales Report for New and Used Catamarans | catamarans | Press Releases | 2 | 08-04-2004 11:24 AM |
| Catamarans: 2004 Sales Report for New and Used Catamarans | catamarans | Press Releases | 1 | 06-10-2004 03:53 PM |
| Merchant ship design software Free or low price.. | Software | 0 | 09-25-2001 07:32 AM | |
