Old 06-15-2007, 07:42 AM
rkpshenoy rkpshenoy is offline
student
Rep: 13 Posts: 36
location of bulkheads
Hey there is one problem i faced lately while calculating volume of tanks required by capacity plan with the help of bonjeans.
As bonjeans are positioned at the stations which may not
necessarily be at the location of bulkheads or frames,i have been unable to calculate the volume of tanks.
Also is there any scheme to position bulkheads to divide the ship ( i mean is there any standard spacing between them?)
Thanx
Old 06-15-2007, 09:38 AM
Rep: 1758 Posts: 1,561
As long as there are no extreme changes in section or knuckles, you can use the Bonjeans to work up longitudinal curves of volume at different heights. You can then slice them anywhere you want for preliminary design estimates. Normaly, however, real tank capacity curves are worked up individually and directly from the finished arrangement/structural plans.
Bulkheads are placed based upon many factors, such as floodable length and volume, secondary structural loading, and cargo factors. If you are designing to a set of society rules (Lloyds, ABS, DNV, etc), they will have something to say about where the bulkheads go and how many you have to have.
Old 06-15-2007, 09:52 AM
student
Rep: 13 Posts: 36
I am presently designing a catamaran with a transverse framing system so im not considering any tanks positioned to the portside or starboard side. instead i am spacing the transverse blkheads longitudinally to divide the tanks. In such case,in the capacity plan i am largely having to divide the demihull into a number of holds.
can i use the bonjeans in that case and how given bulkheads are not exactly where the bonjeans are?
Oh ok i am going by IRS rules and it doesnt give bulkhead spacing.since you are saying its coming under floodability calculations i thnik i can take this from ABS.
Thanx
Old 06-15-2007, 10:46 AM
Are you sure you understand how Bonjeans work? You can use the Bonjeans (curves of area at the stations) to develop a curve of volume along the length of the hull at any height (the sectional area curve, i.e. axis is length, ordinate is sectional area at the station, and the area under the curve is volume). You can then directly measure the approximate volume of any hold space between any two points along the length of the hull. This is basic naval architecture.
Or am I missing something about your question?
Last edited by jehardiman : 06-15-2007 at 10:54 AM. Reason: clarify sectional area curve
Old 06-15-2007, 02:29 PM
Here is an example of what I mean.
Old 06-15-2007, 09:01 PM
student
Rep: 13 Posts: 36
oh ok got your point. but i was talking about the numerical integration part (simpsons rule). notice that in the picture you have shown the tank is not starting or ending exactly at stations. also the shaded area cannot be obtained by applying simpsons rule.
Thanx
tripod
Old 06-15-2007, 09:28 PM
Thanx
tripod
Sigh.... ....I should always rember the saying...
It is not that pigs can't be taught, but rather they will not learn. So never try and teach a pig to sing, it wastes your time and annoys the pig.
Old 06-15-2007, 09:31 PM
student
Rep: 13 Posts: 36
Very funny. I appreciate your sense of humour but this is not the place to use it.
Thanx
Old 06-16-2007, 11:50 AM
Ok, I'll stop trying humor.
I will help you learn, but I will not help you copy.
Based upon this and your other posts, it sems that you are either a student looking for a project to copy, or a builder looking for a vessel to copy (Edit, oh looking further I see that you are a student). Your poor knowledge of even the most basic of marine calculations and requirements is disturbing if you are actually trying to design and build a vessel for service. In either case, it is most likely a diservice to your country and fellow citizens to allow this to go forward as enough people die in poorly designed vessels over there.
But setting your worth and motives aside......and dropping back in to teacher mode....
Query to the student: Why can't you use Simpsons 1st rule, or 2nd, or one of Tchebycheff's, or one of the arbitarily spaced ordinate rules to determine the volume of the tank?
Old 06-16-2007, 02:36 PM
student
Rep: 13 Posts: 36
Thanx for all the concern. But i guess instead of involving yourself in some interactive discussion you are spying on me.why do you have to look at all my posts. If you want to continue this discussion ill give you my mail id instead dont spoil the forum space. rkpshenoy@gmail.com
Thanx again for all the compliments jehardiman
tripod
Bulkheads, Subdecks or .... tttwwwooo Sailboats 0 03-29-2007 04:14 AM
Are Bulkheads Necessary? LBG Metal Boat Building 13 08-24-2006 08:48 PM
ply bulkheads mattoc Materials 6 08-17-2006 08:40 AM
Bulkheads djwkd Boat Design 2 08-17-2006 05:52 AM
Adding bulkheads Ok J Fiberglass and Composite Boat Building 5 05-03-2005 11:45 AM
