| Would the 18ft. Freighter Canoe or a similar variant be acceptable?
| Something like this, but stretched? ![]() I am toying with the idea of something along these lines as I like the high sides http://www.websterstwinfisher.com.au...isplay=130892# To sit on a platform aft of the back beam of the cat I am finishing Plan on building it from sheets of Polycore-Preglassed-Panels and powering with something like a Tohatsu 18 |
| The freighter canoe may not work... we aren't sold on its dockside appeal or the seating for the guests. The PT Skiff is COOL! I like that one. It looks like a launch, which is a great image. It is a bit weighty, but maybe everything in this thread that can carry 6 pax will weigh a lot? I like the price on the PT Skiff a lot. I also like that it could be made from scrap from my build. I really like the Schionning VT-330 and the Webster. When you are making a statement that you prefer cats by owning/building one, you ought to extend that stance to the tender as well. So to expand on that, are there any really small power cats available in the States? What about building a Schionning or Webster out of ply/epoxy?
| You can get a inflatable tunnel hull/catamaran that will take you all the way to the beach and back (ie, right through the surf): http://www.aquasports.cn/?p=12&c=7 Great price and performance (I have one). They have other models if you want something more civilized. |
| How about a power cat that can also function as the power sled for the mother ship? 500 lbs is a lot of weight on a boat for a tender only but fine for something that carries your engines. |
Is there a way anyone can think of to dock a power cat to the mother ship in some way that is seaworthy in "perfect storm" conditions, but that will also allow us to de-mount it for use as transportation and entertainment for our guests? If workable, this idea is brilliant! Thanks!
| I'm afraid to use the proa word but it is an idea I sketched out for a amidships sled while contemplating the mythic beast like everybody else. For a cat having it farther back makes sense. I had the front useing decent diameter aluminum tubing for the pivot with socket clamps on the mothership fabricated out of a lerger section. There are many ways to hinge it as long as it doesn't rack. The back end floating keeps the engines immersed , for fun I even doodled with a long tail version having a central prop between the hulls. A thick enough hull to take the wave impacts and reasonably high retraction complete the package. It is not enough to raise the back end, it also has to be restrained from vertical travel caused by wave impacts. The neat thing is you can have a wide sled with 2 engines and retain good maneuverability. |
| One possibility for your perfect storm conditions was being able to pivot the tender upright onto the capsized under deck of the mother ship for a life boat or tow over assist for capsize recovery. I think that big Atlantic could have used one.... |
#25
| Ahhhh, a tow rope... -Tom |
#26
| And some flooding in one end......For docking I looked at angled rails to guide up the bow pivot tube after attaching a tackle to pull it up into position before clamping or lifting lever hooks. People have had dinghy/sleds before so there should be some out there to look at. |
#27
Never saw it in action but the "talk" was that a couple of pins could be pulled and it would drop in the water and power away on the Yamaha 9.9 4 stroke. |
#28
Daresay lighter as well Preglassed panels would definitely be faster to build |
#29
| Sea Skiffs Here is a Great idea that I bet we could market. Ill help you with the function and shake out bugs if you want to team up. Build a set of three of these Sea Skiffs maybe 24 ft long each Windshields fold down like a Jeep. Each Sea Skiff Nestles and llocks into a docking bay on the hulls of the Catamaran and one in the middle between hulls. Each Sea Skiff has a little Diesil like a Cummins 5.9 TurboIntercooled which drives a Konard I/O drive. you would then have enough power about 1,500HP to drive the big Mother Cat. They are used to power the big Cat fly by wire and undock to do double duty as a lifeboat/Crewboat/Tender,Dive Boat, sportfisher, etc Where in the Northeast are you? Im in southern Maine. Capt Walt ![]() |
#30
| Do a stretch version of the above..
| Ultralight Planing dinghy/tender | deepsix | Boat Design | 8 | 02-02-2008 05:18 PM |
| Discussion of Ro/pax construction | Bening | Open Discussion: All Things Boats & Boating | 2 | 11-10-2005 11:56 AM |
| 8'9" Sailing dinghy/Tender Mold | PMDON | Boat Molds | 0 | 07-12-2005 08:09 PM |
| Yacht Tender/Sailing Dinghy...Need assistance. | mackid068 | Boat Design | 4 | 04-09-2005 06:19 AM |
| Lightest dinghy rig | grob | Sailboats | 22 | 05-03-2004 05:31 PM |
