#31
| oldsailor, was it possible to fold the boat with the rig up? Did you have some way to fold and unfold the boat while aboard? |
#32
| Ray, i think, (but im not 100% sure) that the beams on some cats that have the beam slide in a tube glassed into the hull have the beams quite a bit smaller than the sleeve and then have nylon buttons making up the difference so they wont sieze up and be difficult to slide. Steve. |
#33
| Steve, that makes sense. I'll bet some of that HDPE stuff would be even better. At one point, I had a system designed that used beams sliding past each other within a captive box. There was substantial space around the beams, but they tightened into rigidity when at the end of their travel, they engaged wedge-like structures. They could be cranked open and folded using simple tackles, so that it could be done afloat. The issue with this system that led to me abandoning it was the rig. I wanted to be able to leave the rig up when the boat was folded, because of my personal situation. The slip that is available for my use (from a generous neighbor) is only 10 feet wide, so in order to keep a boat with 12 foot beam in the slip and be able to use it conveniently, the rig had to remain up when the boat was folded. The great advantage to a system that folds at armpits and central spine is that as the spine moves forward and the hulls come together, the geometry can be arranged in a way that keeps enough tension on the shrouds to support a rotating mast adequately. The forestay can be attached to the forward extension of the spine, which when sailing, can be adequately stabilized by a bridle. This bridle will fall slack when the boat is folded, but the central spine will carry the forestay in the same position relative to the mast. |
#34
| Since I only folded the boat to trailer it, I lowered the mast first, then folded the hulls in the water and pulled it out onto the trailer. |
#35
| Okay I dont know if amyone else has mentioned this before now. But we use Nidaplast. Its not a foam but rather a cellular design which must be laminated on both sides before use. Foam isn't really structural whereas Nidaplast is. Plus it comes in various types and thicknesses which is very handy. Once done its very light and damn near indestructable.. |
#36
| Sounds like some stuff that my mate showed me a while age. He uses it to make flybridge floors. Incidentally I am going to use it for a deck on a small cat myself. |
#37
| We use it on every boat we make now. Its great stuff. Of course there caveats. But on the whole its a great product. I reckon its added about 40% extra strength with a weight saving of about 68% to our catamaran decks and stringers. There are a few do's and dont's though. Forinstance its good practice not to lay it directly against the hull, when using for bulkheads. We use a little foam as an isolater between the hull and the Nida. This was a tip given to us by a builder who had been using it for a while. The reason is. Its so strong in compaction that you can get cracks in the gel apperently if you dont use this method. I will try and upload some pics to show this... |
#38
| Horace, that method of installing bulkheads has been pretty much standard practice,even with plywood bulkheads for the last 30 -40 years,particularly with solid glass hulls,although many do not do it. Steve. |
#39
| dont get me wrong, you are correct. Just pointing out that it really is a must with Nida. I have seen makers not doing it though and I was a little shocked. |
| hard top / deck for sale - styrofoam flotation under Pressure Treated plywood deck | WickedGood | Marketplace | 3 | 01-17-2011 08:27 AM |
| how connect center console to deck ? bolts or glue | hyboats | Fiberglass and Composite Boat Building | 8 | 09-21-2010 07:15 PM |
| racing cat for sale 1998 Express Cat hull, deck, 4 gas tanks - no rigging | gcastellana68 | Marketplace | 5 | 11-20-2009 09:19 AM |
| Lightest layup for a female deck/coachroof mould | Roly | Fiberglass and Composite Boat Building | 2 | 10-12-2006 12:14 AM |
| Hard-top ideas for 33' center console | Guest | Boatbuilding | 1 | 06-12-2003 10:59 AM |
