Old 07-25-2006, 05:08 PM
catnut catnut is offline
Rep: 10 Posts: 2
joining hulls
I am considering the construction of a large catamaran.
In principle I would like to make a single matrix for each of the two hulls using foam sandwich.
Then Id like to join the two hulls in a way that does not requiere extending the two hulls but rather use sever beams. On top of the beams I would lay the deck and superstructure.
Is this possible or is it structuraly unsound?
thx, the catnut
Old 08-05-2006, 08:15 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
It can be done, and has been done, but for a "large catamaran" you will want an engineer or NA. There are huge forces and strange twisting moments in unexpected directions, when you look at what goes on in the crossbeams of a cat. Careful design (with BIG safety factors) of the cross bracing is needed to ensure the boat doesn't simply snap in half.
Kayak hull joining question Thin water Fiberglass and Composite Boat Building 12 07-06-2006 12:43 PM
chopping and joining windsurf mast? sigurd Materials 1 06-23-2006 11:55 PM
Joining longitudinals to the frames KajWestergard Metal Boat Building 40 02-14-2006 04:03 PM
Joining longitudinals to the frames KajWestergard Boat Design 0 01-24-2006 02:52 PM
Joining points in Prosurf Willallison Software 2 09-09-2002 06:49 PM
