Old 06-15-2010, 09:08 AM
DennisRB's Avatar
DennisRB DennisRB is offline
Rep: 37 Posts: 435
Jim Brown Searunner 37-40 foot?
What are peoples opinions on these boats? I have been looking at tris and never really considered these as they look like an ugly box. However I had the opportunity to check one out and the comfort level is miles above anything else in the size range. Now I am keen on this model too. How do they sail and how seaworthy are they?
http://www.boatpoint.com.au/boats-fo...aspx?R=3060679
http://www.multihulls.net.au/index.php?page=ed&de=46921
Old 06-15-2010, 01:15 PM
Rep: 118 Posts: 820
They are among the best cruising tri's designed. Check for rot where any hardware penetrates the membrane being especially careful of the stem head fitting. I have yet to meet a unhappy owner (unless they were rebuilding). There are good examples around that can offer a lot of boat for the money. Check out the Cross and Horstman boats too. John Marples still sells the plans along with those for his constant camber updates for the concept. All the Searunner models sail great and have a good turn of speed if not overloaded. The centerboard will get you off a lee shore in a blow.
Old 06-15-2010, 03:19 PM
garydierking garydierking is online now
Rep: 156 Posts: 87
I put 20,000 miles on my 37 around the Pacific and found it to be very seaworthy and easy to sail. The only improvements that could be made are in the materials and their durability in the tropics.
Old 06-15-2010, 11:48 PM
DennisRB's Avatar
Rep: 37 Posts: 435
Thanks guys. What do you mean by durability in the tropics? Do you mean that the ply is susceptible to rot in hot humid conditions? How do you prevent this?
Other than the stem where else are some areas that might be effected? Can a well looked after version of these last a long time? The 2 I looked at are 20 and 30 years old.
Old 06-16-2010, 01:41 AM
Rep: 118 Posts: 820
A good boat can last a long time if cared for, the key to any wood boat's longevity is ventilation. A problem spot on Searunners can be the centerboard trunk area if air hasn't been circulating. Epoxy coating the inside is a great way of preserving the wood which is why boats built with epoxy and coated sell for more money. Every boat needs to be evaluated on its own merits regardless of the design. What were the materials used etc....All marine ply is a definite plus. I wouldn't reject any boat on age but would look at the use it has had and the condition it is in. A boat that has been sailing the coast on vacations will be less fatigued than a boat that has been around the world 5 times etc....The wet hatches on the wing decks are another trouble spot but are easily repaired. There are plenty of these boats in good condition all over the world so look around, you might find one already in a area you were thinking about cruising to!
Old 06-16-2010, 02:49 AM
DennisRB's Avatar
Rep: 37 Posts: 435
Thanks the 40 footer we looked at has been expoxied inside and out. I dont think I would buy any ply boat that hasn't been.
fixing one foot diameter hole in Ferro Hull 32 foot luckyscott Materials 17 01-21-2011 01:45 PM
Jim Young 20 foot Trailer Sailer Ally Boat Design 1 01-03-2011 01:10 AM
Jim Brown – development of the modern multihulls Milan Multihulls 0 03-18-2010 01:51 PM
Synthetic Searunner San Carlos Sonora jmolan Multihulls 5 01-19-2009 02:15 PM
Lorne Brown 1965 clacey Fiberglass and Composite Boat Building 0 04-06-2008 08:05 PM
