| Interperating multi specs Would anyone be so kind as to comment on how to interperate these specs? In terms of sailing performance, relative stability, etc. I might be jumping the gun here, but if these are fairly conservative design specs, is it possible to 'turbo' this boat a little. The design comes from K designs and is a light weight cruising cat. Loa /Lwl 7.50/7.75 m * Beam 4.50 m Draft (ex. Rudder) 0.30 m Draft dagger board down 1.30 m Weight empty approximate 750.00 kg Weight max. CWL 1384 kg Sail area sloop rig 28.60 m2 Sail area Wishbone gaff rig 27.60 m2 L : B ratio hulls 1: 9 B ratio hulls 46,66% effective Outboard engine about 2 x 5 Hp Electric drive 2 x 1.5 kW * incl. rudder Static righting moment 2.200 kgm |
| "L : B ratio hulls 1: 9" These are pretty fat hulls. So that will limit speed however big a rig you put on it. "B ratio hulls 46,66% effective" No idea what that means 750 kgs sounds a bit optimistic for a bridgedeck cabinned cat We use a 6hp LS outboard on our 25ft cat which is perfectly adequate Sailing in the San Juans and Gulf Islands (I write this on Saturna, only about 20 miles from you) means sailing in light winds and flat water. So most European designed boats (including mine) tend to be underrigged. So more sail would be an advantage, but see above. Hope this helps Incidentally, have you contacted NWMA and BCMS - the two local multihull associations?? Richard Woods of Woods Designs www.sailingcatamarans.com |
| Thanks Richard, I've been a monohull sailor all my life, but now look to multis to provide a fast, family cruiser for the San Juans. Having grown up on windsurfers, skiffs and now kiteboards and melges boats, I am looking for something that can happy accomodate a family of 4 for cruising (reefed I'd imagine), but then also be fully turboed for some fun! I see that you have a few designs that might fit this criteria. Also trailerable would be great. Do you have any recommendations? Are there any of your designs that have been built in this area? I am familiar with both strip and hard chined construction and am planning on building myself. Thanks. |
| probably best if you email me using the address on my website, as I see you don't accept PM's Richard Woods of Woods Designs www.sailingcatamarans.com |
| S&S 34 specs | Skippy | Sailboats | 18 | 10-24-2007 02:43 AM |
| Sailcloth specs | danielro | Materials | 4 | 02-07-2006 04:13 PM |
| Design Specs | LP | Option One | 3 | 01-09-2006 11:13 PM |
| sailcloth specs | danielro | Sailboats | 4 | 01-08-2006 04:09 PM |
| Kicker Specs | James Francis | Boat Design | 5 | 03-28-2005 12:08 PM |
