Old 06-03-2006, 11:59 AM
carlosproacarlo carlosproacarlo is offline
Rep: 10 Posts: 2
I BEAMS Poltruded Fiberglass (EXTREN)
Hi
I wanted to know if anybody had any experience or opinion on using poltruded fiberglass I beams for akas or outriggers. I have information on a company called Strongweld and their Extren I beams.
I am designing a low cost no frills coastal 40 ft pacific proa for the Miami area and Fla keys. I got a quote for an I beam of 20ft in length, 12x6x1/2 inch I beam. The price per foot is $41 - so around $800 per aka and the weight per foot is 9 lbs.
Since this is a pacific proa - there will be very little stress in the aka/ama connection as the ama is a wave piercing design.
Flexural Stress Length Wise is 30,000 psi and Flex module is 1.6 x10**6 psi
Flex Stress Cross Wise is 10K psi and module is 0.8x10**6 psi
I am trying to get away with the smallest I beam I can - the one mentioned above maybe over-specs
Any comments?
Old 06-03-2006, 12:17 PM
nero nero is offline
Rep: 112 Posts: 624
seems heavy. Can you make a wood I-beem/keelson for less weight (and the strength were it needs to be) for less money? Of course this would take more time.
Old 06-03-2006, 02:07 PM
Rep: 10 Posts: 2
I was consideing a modified Simpsom type of beam. I saw also from a video of Kurt Hughes a more streamline beam. Both using wood stock and ply. I guess I will have to carfully compute the overall weight of each beam but the I pultruded I beam seemed about 50 lbs heavier
Old 06-04-2006, 11:41 AM
Rep: 593 Posts: 2,054
Multihull pultrusions
Carlos,
Take a look at this boat, the Multimarine L-7 trimaran, and ponder the use of pultruded beams. http://multimarine.com/L-7/L7.html
Chris Ostlind
Lunada Design
I BEAMS Poltruded Fiberglass (EXTREN)-l-7_5_op.jpg  I BEAMS Poltruded Fiberglass (EXTREN)-l-7_49_op.jpg
Old 07-15-2006, 08:56 PM
miked2006 miked2006 is offline
Rep: 10 Posts: 2
Sliding Beam System
How well does the sliding beam system work? I like the simplicity of the idea.
I have a Tremolino and while the consensus is that its a mistake to try to convert a Trem into a folder, I had this nagging idea about a sliding conversion,
aka the L7. Probably a mistake for the Trem, I dont claim to understand the dynamics of the Trem's flexing structure, but idea's are cheap
Mistakes are the expensive part.
Thanks,
Mike Davies
Overhead trolly crain / wood beams nero Boatbuilding 11 07-05-2006 10:33 PM
Parasitic drag from catamaran hulls and beams DSmith Multihulls 9 04-29-2006 02:58 AM
Modelling composite beams in Ansys fencer Software 3 03-05-2006 09:39 AM
Modelling composite beams in Ansys fencer Boat Design 0 02-27-2006 02:41 AM
Flooring beams material? jameshogan Materials 9 03-04-2005 01:51 AM
