  #31
Old 01-08-2012, 08:23 PM
Rep: 457 Posts: 1,404
Doug, it may be a fantasy drawing but that is not like the team to post such a thing. Also it again appears that the main foil is pivoting at the beam/float junction like original H, unlike the big ch. version where the foils pivot at WL. Also, if you look at images of original H sailing; the angled foils do not draw a great depth, that is viewed from abeam. So the new boat drawing of foil depth may be correct. Anyway, we'll find out more soon enough.
  #32
Old 01-08-2012, 08:27 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,598
Originally Posted by Timothy View Post
Do you think in the image that the wing is canted aft and to windward?
Could well be.......
yes, it is a revolution
  #33
Old 01-08-2012, 08:29 PM
For sure, Timothy, the rig will be a canting one - but if this is so in the rendering, then the perspective is wrong and you can't see the slightly angled mast top; it is cut off as if viewed at right angles.
  #34
Old 01-08-2012, 08:33 PM
Doug Lord's Avatar
Flight Ready
Gary, click on the render below and you'll see an approximate flight waterline that I added based on keeping the t-foil foils at least 2 chords below the surface. Note the clearance between the bottom of the main hull and the water, then look at the clearance of the original Hydroptere flying--not even close.....
click on image to see flight waterline:
Hydroptere-61 knots(70.15mph) Peak-hydroptere-maxi-libryd-copy.jpg  Hydroptere-61 knots(70.15mph) Peak-hydroptere_2_78-1-.jpg
  #35
Old 01-08-2012, 08:49 PM
That looks okay to me, Doug, Libryd perhaps, is not going to fly as high (proportionately) as original Hydroptere. Also, if I'm seeing correctly, with the T rudder on the float transom and close to in line with the main foil, and both pressed down to leeward, that will be fine. Another point; the rig is high aspect ratio and the main foot measurement only comes to the cabin, so the sail area is not large ... but the big wing is ... big; they could sail Libryd with no soft sail in heavy wind and still fly.
  #36
Old 01-08-2012, 08:54 PM
Doug Lord's Avatar
Flight Ready
Hydroptere
I know its hard to tell but I think the T-foil rudder is shown on the main hull-just the way it's drawn?
  #37
Old 01-08-2012, 08:55 PM
Timothy Timothy is offline
Rep: 175 Posts: 187
Wild guess. Maybe when heeled its supposed to fly like a moth on only the two deeply emerged lee ward foils the center hull providing longitudinal stability and passive trim control as it contacts the surface.
  #38
Old 01-08-2012, 09:16 PM
Corley Corley is offline
epoxy coated
Rep: 524 Posts: 630
That seems a reasonable contention. Flying higher means more wave clearance but more issues in a nose dive situation as the boat would be at a greater level of pitch when the main hull touches the water and trims the boat.
  #39
Old 01-08-2012, 09:56 PM
Doug Lord's Avatar
Flight Ready
Hydroptere
Banque Populaire uses curved lifting foils and ama buoyancy to allow the main hull to fly "just kissing" the water. The foils are essential to her speed because they support a large percentage of the boats total weight.
Now, I think your suggestion is plausible but not likely because it would not be significantly faster than Banque Populaire V.
My opinion is that the Hydroptere Maxi will be designed to 100% fly in all realistic conditions which would allow her to go faster than a foil assist boat like Banque Populaire. I guess we'll see for sure in the not too distant future...
  #40
Old 01-09-2012, 07:54 AM
Doug Lord's Avatar
Flight Ready
Hydroptere
e-mail from Team Hydroptere regarding the site:
Dear Doug,
Thank you for your email and for the deep interest you show on your forum.
As you pointed out, English translations have been lacking since mid-2011, it is a problem we will try to fix as soon as possible as we know that most of our readers don’t speak French.
The project is currently evolving, that is why the official website is directing to Alain Thébault’s website. We can only ask you for some patience, l’Hydroptère will be back soon.
Best regards,
Thomas
L’équipe Hydroptère
Boîte Contact
contact@hydroptere.com
www.hydroptere.com
  #41
Old 01-09-2012, 11:37 PM
gypsy28 gypsy28 is offline
Rep: 54 Posts: 95
Dear Doug,
Gee dont tell him that he posts enough already without OWNING the forum haha just kidding Doug, love your stuff
DAVE
  #42
Old 01-10-2012, 12:24 AM
BPL BPL is offline
Rep: 115 Posts: 154
Great renders Doug - thanks for linking them.
Wish there were a front and side view with all three inline.
  #43
Old 01-11-2012, 08:12 PM
P Flados P Flados is offline
Rep: 212 Posts: 225
On BPV they like to fly the main hull as described, but their biggest speed penalty came in rough seas when they had to go slow (Ok 30 knots is not really slow, but you know what I mean) to avoid excessive hull slamming loads.
The Hydroptere Maxi does not have to do 100% fly all of the time to be a substantial improvement. Flying high enough and level enough to just slice through wave peaks should allow high speeds in the rough without excessive hull pounding. I am thinking that achieving good attitude stability is more important than ride height. Flying high, but crashing down just before as the next wave gets to the boat would be very not good.
  #44
Old 02-20-2012, 09:31 PM
Doug Lord's Avatar
Flight Ready
Hydroptere: the Fastest Sailboat on the Planet
Well, I think I just discovered why the Hydroptere website has been dead(see post # 40) and jumped to Alain Thebaults site: they've had a major change in sponsorship and ,apparently, were close to the edge(my speculation). This is Thebaults site, not the "old" Hydroptere site: http://www.hydroptere.com/ The site is not back up but there is new info on Thebaults site about DCNS and there are these:
Hydroptere Mega-click on image-
Hydroptere-61 knots(70.15mph) Peak-hydroptere-mega-hd-final04.jpg  Hydroptere-61 knots(70.15mph) Peak-hydroptere-mega-hd-final05.jpg  Hydroptere-61 knots(70.15mph) Peak-hydroptere-mega-hd-final06.jpg
  #45
Old 04-10-2012, 08:04 PM
Doug Lord's Avatar
Flight Ready
Hydroptere-Fastest Sailboat on the Planet
Pictures of the new paint job: http://sealaunay.photoshelter.com/ga...001NXc3eVIvAw/
Design for Speed and Efficiency-Lessons from Hydroptere Doug Lord Multihulls 10 04-05-2010 04:16 PM
Hydroptere new record bistros Multihulls 5 11-12-2009 04:07 PM
Hydroptere Maxi Doug Lord Multihulls 2 04-17-2009 01:04 AM
hydroptere 52.83 knt bertho Boat Design 2 10-08-2008 10:56 AM
Hydroptere takes new direction Chris Ostlind Sailboats 2 05-30-2006 03:27 PM
