#31
| their winglets have winglets Damn, their wing have winglets and their winglets have winglets! |
#32
| Keep going lesburn! Soon you'll have that quirky loop keel that somebody was trying to flog on here a few moons ago. |
#33
| Doug, regarding Brett Burvill's foiler... Do you remember any figures about speeds attained with this foil configuration? |
#34
| Private, temporary and off-topic You are right, dear anonymous reader - it was all unecessary and uncalled for. But that's what this forum is about, an exchange of opinions... Sometimes right and sometimes wrong ones. ![]() |
#35
Daiquiri, I think it was the very low twenties or high teens. It wasn't until the bi-foiler configuration was used that speed really took off-theres a sort of history of the bi-foiler version in "Moth on Foils" since every class speed record is documented....
#36
| Returning to the original picture of l'Hydroptere inverted, there are a few other features of note. The amas are designed with a planing step and look much more like a flying boat float rather than a convential tri's ama. The main foils have a deep hollow in the pressure face indicating a leaning towards cavating foils or at least agressive camber forward of the 1/4 cord point. Hovever, photos at http://foils.wordpress.com/2008/12/0...e-les-100-kmh/ show little cavitation. The main foils have flow fences on thier backs (low pressure side) but not thier faces. The rudder/strut has flow fences down its depth. The rudder/strut lift foil has winglets on the ends for both the face and back.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
#37
Opinions are personal expressions. Since you are a guy with your own personal expressions, both for and against, you should already know that they come and they go based on the moment of the expression.... you don't really feel that your expressions are timeless and more important than those belonging to others, do you? If you do, that would put you in the same category as Berlusconi and no self-respecting boat guy would want to identify with that particular sociological bent, would they? ;-) |
#38
| Noooo Chris... maybe you didn't understand the sense of my post (and you rightly couldn't). ![]() I got a negative rep with a one-word explanation - "necessary?" So, not knowing what was that suppose to mean, I made a guess that the message was "did you really have to write all that crap?" and, based on that, have replied to the anonymous guy, hopefully in an educated way. I don't care too much about positive and negative points anymore. Though I did care once... for pure vanity, I guess. Negative reps mean nothing in my (or yours or whoever's) ordinary life and don't give or take anything to my daytime job or to my knowledge. If one disagrees with what he reads, then rather than leaving uncomprehensible comments and negative reps, he can write his opinions down in an argumented post... That is how one can make a difference in other guy's life through this forum, and spread the correct knowledge. A correct knowledge gained in that way is valuable and very appreciated indeed. How can I be against other people's expressions anyway? I learn something new each time I come to this forum! ![]() |
#39
| So, which one of us gets to be the designated decider of said correct opinion? Remember that not all of the information discussed on this Forum is quantifiable. A good deal of it has to be perceived and sorted by other means. Unfortunately, in the rush to explain everything about sailing with math and engineering principals, the obvious part about our humanity just gets pushed aside. It's a sad day, indeed, when we forget to honor the most essential component of our make-up... the part that was there long before anyone thought to devise the math aspect with numbers. So, I guess that maybe you couldn't rightly understand, either... How could you? |
#40
| Look, I truly and sincerely don't understand what you mean... Call me dumb or whatever you want, but I don't. ![]() Where in particular did I loose my humanity in this discussion, according to you? |
#41
| a system of valance , winglets and hull frequencies in hopes of achieving a sectional true up ward stability using frequencies .to ease the push friction possibility of water molecules around surfaces to reduce drag |
#42
| downward projecting vertical tips
| Winglets on sails? | champ0815 | Sailboats | 37 | 03-23-2010 12:20 AM |
| hydrofoil | jejojoy | Propulsion | 2 | 09-25-2006 09:50 PM |
| hydrofoil | jejojoy | Propulsion | 2 | 08-24-2006 01:08 AM |
| hydrofoil | jejojoy | Boat Design | 3 | 06-20-2006 09:04 AM |
| Rudder "winglets" | Bill Nordby | Boat Design | 1 | 03-07-2004 03:11 PM |
