| Hybrid 6.3 metre cruising trimaran The start of this discussion was "Fixed or rotating mast' but the focus has changed onto the hull shapes so it seems best to start a new thread. I'd also like to thank those long-suffering members who have contributed so far to the debate and hope I have learned something from their input. The main argument stated by various members was the lack of flare on the Trinardo hull Kjell designed it for closed Swedish waters and a wave height of around 300 mm. Here is Eastern Australia, anything up to 3 meters might be considered normal. The boat will be for cruising only and do not care about the top speed - comfort and safety and much more important. The payload with 2 persons and cruising gear should be around 500 Kg Here is the status so far:
[*]It still fits comfortably between the ama-supporting points on the trailer[*]More usable usable space and headroom [*]Would still work with my modified beam structure with only minor changes[list] Coimments on suitability of the Catri Vaka would be very welcome. Another question is - are the A Class Amas too small to work with this Vaka? Thanks and regards Alan |
I dicked around with this donor tri idea for years after being offered a cheap Tornado. It is tempting to try and save money this way. But what you could end up with is something (a submersible float tri) whose time has long gone. That said the Kelsell Typhoon was successful but had a far more minimalist main hull than the one under consideration here. http://monstersailing.blogspot.com/ check NACRA 5.8 Based Trimaran |
| An A class has an effective length of say 5m, hull width 200mm, depth 300mm So total disp is 5 x .3 x .2 max = .3T That doesn't sound a lot does it?? A 6.3m trimaran will probably weigh 400kgs min plus crew and gear say 200kgs min. So I think you'd need to look for at least 6ookgs disp on your outrigger. For a 6.3m mainhull I'd be very tempted by the Hobie 18 On my Strike 18 trimaran I used 18sqm hulls but I cut them down to 4.8m (16ft) by cutting just in front of the mast beam. A lot of work even though they were solid glass hulls which are much easier to join than foam hulls. Richard Woods of Woods Designs www.sailingcatamarans.com |
| Thanks Richard This is exactly the specific detail I need to work out what to do. There may be a couple of different ways to fix this and your comments would be invaluable. The options seem to be as follows:
As mentioned earlier, I'm semi retired and time/labour is no problem - money is. Regards Alan |
| Forgot to mention that the existing A Class hulls are actually thin ply with a few internal timber stringers and some foam stiffeners. It looks as though the gelcoat was applied straight over the ply so there is virtually no strength in them. This the other reason why a glass/epoxy outer skin will be applied, so bulking up the shape with foam at the same time is no big deal Alan |
| Sorry I haven't read all the previous thread, but I have now. As you said starting a new one makes sense. Its getting boring, but again I agree with Catsketcher, get a Hobie 18. The A class hull (and rig to be honest) is probably the worst one to use. Imagine coming off a wave at speed, close to pitchpoling. There is a lot of load out there on your outrigger bows! You don't want to do a Team Phillips I think you'll find it quicker to start a new outrigger from scratch rather than try to add foam and glass, always a complicated thing - how do you then attach the beams (make new bhds, keep the same mountings on a wider heavier hull?) and how do you fair it into the bow? Never mind the hours fairing the glass overlaps you'll have. Sorry to be negative, especially after you've made a start. Richard Woods of Woods Designs www.sailingcatamarans.com |
| 12 Metre design | phum | Sailboats | 41 | 10-25-2009 09:34 AM |
| Trimaran skiff hybrid | frosh | Multihulls | 6 | 10-04-2006 01:22 AM |
| Solid Foam 12 metre | MikeJohns | Boat Design | 7 | 02-05-2005 03:23 PM |
| 12 metre model yacht | Tranth | Sailboats | 6 | 05-04-2004 03:23 PM |
| 12 metre (australia II) plans | Goodwin | Sailboats | 4 | 02-03-2004 01:51 PM |
