Old 04-27-2008, 02:16 PM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 484
How to dimension a sailing catamaran?
Hi all,
Couldn't find this kind of document from literature or net. I had to do it myself. I also modified catamaran parameters to mach the document.
There can be mistakes and misspelling, I'd like to get some feedback.
Have fun
Terho
Old 04-27-2008, 07:14 PM
nero nero is offline
Rep: 112 Posts: 624
Wow! ... and Thank you!
Wish this had been published 4 years ago! You will become the guru of catamaran design when this .pdf gets know and refined.
Old 04-28-2008, 08:10 AM
Rep: 660 Posts: 664
Thank you
Hello
I just spent half an hour playing with your spreadsheet. I really like it. I did want to do something like this myself but never did. It is very simple to be able to fiddle around with dimensions to be able to get the characteristics you want. It is very impressive.
Is there anything I can do my end to help. I can spell pretty well. Would you like me to go through and fix the spelling up? Anything else?
cheers
Phil Thompson
Old 04-28-2008, 11:18 AM
terhohalme's Avatar
Rep: 478 Posts: 484
Thanks Phil
send you a personal message
Terho
Old 04-28-2008, 12:18 PM
JCD JCD is offline
Follow the Bubbles!
Rep: 36 Posts: 359
Hello Terho,
Originally Posted by terhohalme View Post
Hi all,
Have fun
Terho
Outstanding. If there is anything at all that I can help with...just ask.
Excellent work! Funtime is here.
J
Old 04-29-2008, 02:41 PM
terhohalme's Avatar
Rep: 478 Posts: 484
New version of catamaran parametric study
Hi all,
Redefined catamaran parametric study. Now, there is included a calculation of design righting moment for rig design.
Terho
ps. Redefining of document is on going...
Old 04-29-2008, 06:45 PM
JCD JCD is offline
Follow the Bubbles!
Rep: 36 Posts: 359
Hello Terho,
I want to thank you again for your contribution. It has helped me with quite a bit and it has further reinforced my effort to continue to work hard on the TR27B.
I'm attaching the spreadsheet so that you can see the results of the actual dimensions of the TR27B in your spread. There were some places where she may have done better and didn't meet certain accepted values, but she still met the Category B requirements. She is at her lightest displacement. I did it in heavy also, but that just brought the SF higher to 24000+. I gotta tell you that the results were really close. The displacement was off by less than a cubic foot (60#'s).
Again, excellent work, and if you need a bodyguard when the NA's and NE's go after you for revealing all their secrets, let me know.
J
Old 04-30-2008, 12:21 AM
terhohalme's Avatar
Rep: 478 Posts: 484
Don't believe that. The world is full of good books of physics, still the majority of educated people don't understand it. The physicists can have their job.
The only way to increase knowledge is to share it. I think this is one of the secrets of science too. Our greedy businessmen just think they can have it all to make profit for themselves.
Old 04-30-2008, 01:42 AM
Spiv's Avatar
Spiv Spiv is offline
Ancient Mariner
Rep: 195 Posts: 168
....The only way to increase knowledge is to share it.....
Great work Terho, I've made a few aesthetic changes, hope I get your endorsement...
Keep smiling
Stefano
Old 04-30-2008, 04:59 AM
Rep: 660 Posts: 664
A few thoughts
I love this thing. I did do something much simpler for an engineering problem I had. This is great. With my small cats I have a bit of an issue with stability. Using a program to fiddle is much better than me with a calculator.
I have included a few remarks with the attached Jpeg
BTW - this is a software question but how can I look at the code behind the cells?
cheers
Phil
Old 04-30-2008, 05:00 AM
Rep: 660 Posts: 664
Jpeg
Here is the Jpeg
Old 04-30-2008, 05:41 AM
terhohalme's Avatar
Rep: 478 Posts: 484
BM's are metacentric heights (in metres) from the center of bouyancy to metacenter.
You can take of protection of the table, there is no secrets, all the formulas are puplished earlier.
Use the newer version...
Old 04-30-2008, 03:15 PM
JCD JCD is offline
Follow the Bubbles!
Rep: 36 Posts: 359
Hello Terho,
Well amen to that. I don't care how much trouble I go through...I share openly.
The spread really seems to be taking off. I'm really glad to see that. It makes everything soooo much easier.
J
Old 05-11-2008, 11:41 AM
terhohalme's Avatar
Rep: 478 Posts: 484
Hi All,
Made some corrections and refining. Moments and windspeeds should be now clearer. There is also an imperial version of excel spreadsheet for those not familiar with metric physics.
Terho
File Type: pdf How to dimension a sailing catamaran.pdf (86.8 KB, 577 views)
Old 05-11-2008, 07:16 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Hi Terho,
Best I've seen in a while... great stuff From now on you're my best friend and best friends help each other, right
I have roughly compared my cat to your cryteria, it comes close to the nearest lamp pole, result of long late nights reading reading reading.
Very nice and thank you !
Regards
Fanie
Water ! Just gimme water !
Sailing catamaran parameters terhohalme Multihulls 21 09-28-2009 09:25 AM
Motor sailing catamaran rig design cat girl Multihulls 19 09-30-2006 06:09 AM
Aluminum Catamaran for sailing and cruising searoy Metal Boat Building 4 09-24-2006 02:19 PM
44' Sailing Catamaran Hull fhrussell Boat Molds 3 03-11-2005 09:22 AM
Sailing Catamaran steering Geometry lyndon Boat Design 4 07-24-2004 07:34 PM
