  #121
Old 07-11-2011, 09:50 AM
Boat Design Net Moderator Boat Design Net Moderator is online now
Moderator
Rep: 647 Posts: 184
Originally Posted by lugnuts View Post
I notice that Delane's link to his conversion on you tube has been deleted from this forum. Is it against forum rules to link to youtube? Just wondering...
No there is nothing wrong with including a youtube video. Delane started a new thread here:
Vitamin Sea - J-24 Tri Conversion Videos
Please be polite to all other members. Please respect those who take their time to give advice freely. And please keep threads on topic. Forum Rules
  #122
Old 12-22-2011, 04:54 AM
Delane's Avatar
Delane Delane is offline
Rep: 37 Posts: 86
Tri Conversion (Phase 2)
Well here we go!
In the planing stages of determining materials, construction method and dimensions for the soon to be added hump section for the Vaka. Yes, I'm effectively going to change the shape of the Vaka by adding the equivalent of another Ama under the Vaka thus changing everything, and hopefully for the better. In the end I intend to achieve a dryer, faster boat with minimum added weight. Initial thoughts are to construct in a (U) shape blumb on both ends thus taking out the rocker in the hull. Studying Canoe building methods now which I hope will prove helpful for my endeavor. Considering using either one of the following materials for the formers (sheet FRP, epoxy coated ply, thick surfboard foam, aluminum ) and would appreciate some suggestions there. Also haven't decided which material to sheet with (thin ply or foam ) before glassing up. Thanks in advance for any help!
  #123
Old 12-25-2011, 11:25 PM
harrygee harrygee is offline
Rep: 20 Posts: 7
Hi Delane
The work on your modification might be easier with the hull inverted or you could make a mould, using cheap junk ply faired with plaster or cornice cement. Then you could make a bolt-on conversion, which could be bolt-off if it's a flop.
Taking out all the rocker, as it appears on your profile, will make it a bit reluctant to tack.
I can understand your comments about the wet ride; my own soling conversion throws a bit of water around above 12 knots, becoming a fire-hose at 15 knots. Great fun though. It's a bit more of a "mongrel" now, as I broke the mast a while ago, caught in a 40 knot blow. The soling sails had no reefing and dropping sail would have been dangerous, so nature dropped the rig. The cheapest replacement was an old dragon rig so I now have 20% more sail. That's what you do when the rig breaks. I also have a big reef.
I love my boat. It's cost me half the price of a ply trailer tri, even with the broken rig and I've had a lot of fun building and sailing her. Highest speed recorded on the GPS is 24 knots on the day the rig went, when I suspect there was very little of the soling in the water. I'll try to get an action shot to post, she looks the part when the spray is flying.
Take care
Harry
  #124
Old 12-26-2011, 02:11 PM
upchurchmr upchurchmr is offline
Rep: 224 Posts: 529
I hope you draw this up before you start making things.
If you put an ama under the Vaka you are going to float this very high. There is no purpose in doing this. If you are going to build another ama anyway, just make a whole new Vaka.
I suggest you just use the J-24 hull without adding the hull changes. It has worked for one guy. Be happy with that.
If you put a bottom hump on the J-24 how are you going to attach the aka's? Sloping down to the amas?
Bad.
Marc
  #125
Old 01-01-2012, 07:53 AM
Delane's Avatar
Rep: 37 Posts: 86
Hello Harry,
Sounds like you're having a blast with your creation! Would love to see some action video some day. Thanks for your suggestions and yes I thought about different methods of building. I'll post some visual aids of my building plan when finalized. Simple, strong and effective is the goal.
Marc,
Thought about drawings and I'm not adding a huge hump so large that it's going to float me up over more than a foot. When I build the form I can roughly calculate the volume and this have an idea how much rise to expect. The goal is to minimize the drag effect of the (mono hull) and cause the hull to perform more like a purpose built Tri with a similar shape. Will also drop down the Ama's to compensate for the rise. Think when i post some drawing this will become clearer. The boat will reach her full potential, I won't be happy with anything less.
Happy New Years Everyone!
  #126
Old 02-08-2012, 07:49 AM
Delane's Avatar
Rep: 37 Posts: 86
Commitment Phase (Building the Hardback)
And with that said, the trailer/boat is leveled and hardback is constructed for lack of better words and soon will finalize the fabrication of my station jig pattern thingamajiger that will slide down the hardback to each frame location. I'm looking at two options for the stern most frame. 1. Start out fat and plumb with the stern (U shaped measuring 22D X 20W) and continue forward until terminating in a sharp wave cutting nose that will extend past the original waterline by nearly 16 inches. Or option 2. Start with a tapered stern frame ( 10D X 10W) to reduce the affect on rudder control and to control excess volume in the stern. On the web I encounter two schools of thought on stern profile and the answers vary based on the boat era, type of Tri and the Author. I've decided to use 10mm ply for the frames and sheeting prior to layup but may consider other options. And because many will ask, the hardback is only there for determining the shape and exact location of the frames. Afterwards I'll set up the hardback next to the boat, narrow the top pipes and slide the frames (each having two each alignment holes same as the pipe) into position upside down, add stringers/sheeting and begin to glass. When completed I'll cut the slot for the dagger board, lift the boat up and slide the completed hull assemble up to the original hull and tab it into the hull and glass around the dagger board slot opening. I welcome and suggestions that may help achieve the desired goal. I've never built a hull like this and only going with what I know and have studied on the web/forums.
  #127
Old 02-10-2012, 07:25 PM
Delane's Avatar
Rep: 37 Posts: 86
Photo's of Hardback/Frame Jig
Thought I would post some photos of the beginning phase of the project. Still debating on exact hull shape and would appreciate some input. One thought was to make it the same as the H-20 hull but maybe 20% larger.P2050474.zip
P2050475.zip
P2050476.zip
  #128
Old 02-21-2012, 11:23 AM
Zeeerga Zeeerga is offline
Rep: 10 Posts: 2
A mono hull thinking about tri
I have a 16 footer fiberglass monohull, and the image of 2 outriggers attached to the sides passed by my dreams many times... The topic with its 9 pages with all this development, almost brought tears to my eyes,
I have a friend that have an old 14 foot HC forggoten in his backyard, and those ideas came back again to my mind.
IŽm not thinking in convert my monohull in a tri, but to make a central hull for the 2 floaters. (maybe convert ,maybe not...)
Cause of my line of work (Laser cut and robotic welding supervisor) I can use laser cut almost free, and I was thinking about using some of the F concepts, (foldable) in a pair of struturaded (like a airplane wing) aluminium arcs made of a hollow irregular boxes linking one ama to each other, and in the middle, attaching to the central hull, without making considerable holes, almost like a ring around the hull in the 2 conecting areas.
What proportion should I use, by your experience, for the HC 14 floaters, would be the size of the central hull? use the 24 to 20 like yours? Or would be in my case 16 to 14, more or less?
And if try to make a new central hull, should have a narrow plannig form?
Sorry for my mistakes, cause english is not my first language
thanks,
Serguei - Brazil
  #129
Old 02-22-2012, 07:56 AM
Delane's Avatar
Rep: 37 Posts: 86
Serguei,
Well you have lots of options.
1. You could use the 16 Mono with the 14 hulls and have a fun little boat with great performance. Fixed beams would be the easiest but you could build them to slide/fold to make trailer-able.
2. You could build a Vaca (Center Hull) maybe around 20 feet long U shaped measuring around 2 feet across and maybe 3 feet deep with about a 14 to 16 foot beam. Some have built similar boats and they really zip along quite well if you don't mine getting a little wet.
Search a little on the forum, you might find others that have done similar projects and may inspire some great ideas.
  #130
Old 02-22-2012, 08:22 AM
Rep: 10 Posts: 2
Thanks for the repply, IŽll grow this idea of a tri, remembering these 2 amas in my friendŽs backyard,.
Im reading all that I can in the forum, and the slide concept now works better for me, IŽll read, read and read before deciding the way to go.
In your videos, your J24/HC20 seems to sail very nice. Congrats for her
Serguei
  #131
Old 05-08-2012, 07:37 AM
Delane's Avatar
Rep: 37 Posts: 86
The Need For Speed! Progress of Phase 2
Note sure if you can really call her a J anymore but here's some of the progress this far. Current plan is to float after Gelcoating to establish new waterline and then drop the Ama's and Motor mount. Decided to offset the rudder to the Starboard side of the new appendage. Yes the tiller will still be in the center though.
  #132
Old 05-08-2012, 07:45 AM
Delane's Avatar
Rep: 37 Posts: 86
More Photo's
Rudder location. Not mounted, just taking a look. Thinking about mounting swim ladder in the middle.
  #133
Old 05-08-2012, 08:08 AM
oldsailor7 oldsailor7 is offline
Rep: 269 Posts: 1,118
Words fail me.
  #134
Old 05-09-2012, 06:37 AM
I'm sorry Delaine, I am not trying to be Snide. But I really don't know where to start in commenting on the evolution of your Tri.
I have never liked the J24.
I always considered it as a fat little Mono with a heavy keel. It's performance was nothing to write home about ---but it was a successful class racer.
As a pocket cruiser it was unpleasant. It rolled horribly, it had convex decks, it had low "safety" rails which were so low they were more likely to trip you overboard rather than save you.
A couple of years ago I was offered one for free because the owner couldn't sell it.
I turned it down.
Although the hull has a typical mono low B/L ratio, stripped of it's dead weight keel it has the opportunity to plane, given enough sail power. As a Tri you had the opportunity to add a great deal more sail power.
Your conversion was sufficient to give you a pleasant sailing boat, although I worried about the holes you drilled in the cross arms and the lack of water stays.
Water stays protect the crossarms from bending stress and convert it into compressive stress which the tubular arms can handle very well.
However I can't understand why you wanted to add the add the underbody to the hull except for its ability for reduce leeway. It is a good semicircular section for low friction drag, but the straight keel line
is going to slow down your ability to turn quickly and the flat back end is going to produce a lot of vortex drag and turbulence which will affect the operation of the rudder, particularly when turning to Port.
Just my 2C worth.
  #135
Old 05-09-2012, 09:23 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,598
For some reason I can't open those files-any chance of a jpeg?
yes, it is a revolution
Trimaran help !? Guardian Boat Design 22 11-08-2006 07:47 AM
looking for a 21 ft trimaran arzpengwen Boat Design 3 09-13-2004 09:01 AM
Fishboat Conversion Powerboats 19 08-03-2004 11:43 AM
Trimaran - Pontoon Design TSITL Boat Design 3 07-08-2004 04:42 PM
Sunfish Conversion? Rowdy Boat Design 3 04-27-2004 08:42 PM
