Note: This feature may not be available in some browsers.
===================Doug, this is a fantastic looking model. Have you tested it on the water? Can you explain how it is supposed to self-right again? I saw something early on in the thread about the righting moment both lateral and vertical if it were to pitch pole. I was trying understand the mechanics of what would actually happen. Are the extended foils heavy enough versus the bouyancy of the tops of the amas? What would cause the capsized model to right itself?? I am new to the forums but I am excited by all of the designs I am seeing!
----------------Doug - thanks for the hearty welcome! And thanks for your explanation! Sounds like there is a lot going on with this design! As long as you are using the mast's bouyancy to help right the trimaran, do you think perhaps making say the last foot of mast its own bulkhead with a manual release airbag would be of any help? I think this is a great idea, because it helps to tackle the one issue other than hull separation that would most likely create an issue out on the water. I also like the idea of the deployable hydrofoils, as I have heard that in the shallows or in fishing areas you can get caught on lobster traps, trash, and such that could rip your hulls up before you are up and planing. Great job on the design so far! I hope to see more!
I'm considering fairings on the crossarms to reduce aero drag-after she flies the first time. Cost ,in terms of weight will be offset by the better aerodynamics.
----------------------Doug, this is a very space age looking design! Does some of the lift come from the aerodynamic foils that span the beam just where they connect to the amas? Have you also run the model through a wind tunnel simulator? There is a free wind tunnel simulation software called Falcon. I don't remember who puts it out, but I think it is a joint effort between one of the CAD software companies and a large engineering university. I have not used it yet myself, but supposedly it can work with 3 models. I don't think it is set up to calculate hydrodynamics as well. I just got delftship, but am in the learning stages. I know it has hydrodynamic calculations on it but I am not certain if it can do wind tunnel type simulation. Maybe there is a software out there that does bi-laminar flow? IDK...
I just found Falcon:
Poject Falcon
Hats down for all that effort, Doug. Very neat work.
The benefit imo will depend on how you intend to make these fairings, and how big. The risk (with a dihedral your crossbars have) is to create windward lifting surfaces set at an angle of attack to the wind, which will hence create lift and contribute to the heeling moment, especially in the event of a pitchpole.
Good luck for the testing!![]()
