  #2536
Old 04-16-2017, 08:02 PM
Doug Lord's Avatar
Flight Ready
Rep: 1362 Posts: 13,710
WOLF---daughter of fire arrow / Concept Model / Two Level Seating
I've been studying the mock-up of the two level seating and I may have a better idea for the upper level.
The whole point is to allow me to move further outboard in conditions where an initial increase in RM is necessary to get started-not necessarily to use on a regular basis since after the boat is flying the extra RM won't be necessary most of the time and to the extent it is mainfoil downforce can do the job.
So the idea is to install a tramp from the back of the lower seat to the ama "curved piece" and to add a foldable -and perhaps slidable-back between the two crossarms so that if I use the tramp I'll have some back support. Seems better and lighter than two additional "hard" seats that will be used relatively infrequently.
Going to tentatively go with this initially.
yes, it is a Revolution
WOLF-daughter of fire arrow
  #2537
Old 04-16-2017, 08:16 PM
Doug Lord's Avatar
Flight Ready
Fire Arrow Foil System / Ama foil
Fire Arrow planing ama: (STB UptiP foil still has iFlap-removed from port ama foil)
  #2538
Old 04-16-2017, 08:23 PM
Doug Lord's Avatar
Flight Ready
One of the wildest things that has happened in a while took place a few months ago when it was discovered that Maserati was the FIRST fullsize trimaran to use a lifting foil on the daggerboard in combination with an UptiP foil on the stb ama!!!!!
Very similar to the Fire Arrow configuration conceived of 6 years ago and tested successfully in light air two years ago!
And Maserati is about to race with this complete configuration for the first time in the Transpac in July. She had a collision with a ufo that destroyed her stb rudder t-foil just before the Malta race. She got lucky and won that when Phaedo made a mistake. Her next race was the Carribean 600 where she raced with a third of her foil system non-functional again and finished within 12 minutes of Phaedo even with that monumental handicap.
Thats why the Transpac is so important: she has a real chance to finally beat Phaedo outright!
Here's what the Maserati guys say about the basic Fire Arrow system-it may sound familiar to anyone that has read this thread:
First* trimaran in the world to fly with effortless stability on the horizontal loading-bearing surface of her centerboard, Maserati Multi70 brilliantly puts into practice Guillaume Vernier and his Team’s idea of flying on three resting points using a load-bearing centerboard, L-foil and a rudder instead of the two rudders and single foil adopted on America’s Cup cats.
Giovanni Soldini and his Team are engaged in a new challenge as they endeavour to turn Maserati Multi70 into the first ocean-going flying trimaran. An ambitious project that spans not just Guillaume Vernier’s excellent work (he worked on the modifications to her appendages) but also over 4.000 nautical miles of sailing clocked up by the Team this summer.
The straight central daggerboard plays a revolutionary role in this new flying trim as the horizontal load bearing surface at its end generates lift, raising the boat out of the water. “When Maserati Multi70 rises up on her lateral foil and rudder, the daggerboard wing acts as a third resting point – the central and largest one”.
Tests in wind of 40 knots have demonstrated that Maserati Multi70 is now much more stabilized and able to fly in conditions unthinkable before. Safely tackling also big seas.
* Fire Arrow was the first trimaran to use this configuration!
Maserati
  #2539
Old 04-17-2017, 05:17 PM
Doug Lord's Avatar
Flight Ready
Here are a couple shots of the upper level seating changed to (mostly) a tramp on each side. See the top of this page to see the change. The adjustable seat back is not shown:
  #2540
Old 04-19-2017, 05:02 PM
Doug Lord's Avatar
Flight Ready
Another view of the tramp/upper seating. I'm pretty well sold on this because it allows the ultimate comfort that I want as well as the ability to sit outboard when required comfortably and quickly:
15.5' LOA(minus rudder)
18.75' Beam (folds to 8')
  #2541
Old 04-21-2017, 05:59 PM
Doug Lord's Avatar
Flight Ready
WOLF---daughter of fire arrow / Foils
One thing that was learned in testing the model is that in waves it would be ideal to be able to lower the ama foils from their standard position. Out of the question on the Test Model because of the extra weight and radio complication.
But on Wolf it should be a simple thing to do, so the Concept Model will reflect UptiP ama foils that can be lowered around a foot(.3m). The rake of the ama foils will be adjustable but probably not the cant. I want the foils to be simple to sail with with the fewest regular adjustments possible. One thing that is unique about the ama UptiP foils on the Test Model and on Wolf is that they don't have to be retracted/deployed every tack or gybe like the UptiP foils on the AC cats, Flying Phantom, GC32, NACRA FCS 20 and others.
I'm still thinking about having a recess in the main hull to allow the daggerboard foil to be retracted above the bottom. That will leave a hole in the bottom which may be able to be dealt with using foam or? So it fills in automatically as the foil is lowered. The daggerboard foil will use a flap adjusted by a wand-either one like the Whisper* or similar to the dual wand set-up on the Test Model(below).
The rudder T-foil will pull straight up and clear the transom/bottom intersection.
*See the Whisper wand system on page 165, post 2463
Fire Arrow Test Model Dual Wand System:
  #2542
Old 04-22-2017, 11:53 AM
Doug Lord's Avatar
Flight Ready
WOLF---daughter of fire arrow / angle of heel
These illustrate two angles of heel for Wolf:
UPDATE: made a mistake on Sketch C-will redo correctly at some point. Sorry.
Sketch A-13 degrees angle of heel-illustrates boat with mainhull flying 5 inches above the water with the ama planing surface aft end flat on the water:
Sketch B-10 degrees-illustrates mainhull floating and the aft end of the ama planing surface just touching the water. See Sketch C for a better illustration of this:
  #2543
Old 04-23-2017, 12:23 PM
Doug Lord's Avatar
Flight Ready
WOLF---daughter of fire arrow / Angle of heel /Altitude
These three pictures illustrate angle of heel and, in two, flight altitude:
Sketch C shows main hull floating and ama just touching with the boat not moving:
Sketch D shows the nominal flight altitude and angle of heel for relatively smooth conditions starting from takeoff in 5 knots of wind:
Sketch E shows the nominal flight altitude and angle of heel for rougher conditions:
  #2544
Old Yesterday, 05:40 PM
Doug Lord's Avatar
Flight Ready
Fire Arrow Test Model Testing and Development / WOLF
The dihedral of the crossarms on the concept model is about 1/3rd more than on the Fire Arrow Test Model and I'm considering reducing it.No decision yet but I have the model set up so I can study it carefully. I'm looking at the numbers for initial RM and max RM and other considerations including capsize/knockdown response and more.
UPDATE: Definitely decided to reduce the dihedral but haven't decided how much yet. Greatest benefit is getting moving easier in stronger wind......
This picture shows the minimum dihedral on Fire Arrow which occurs with the main hull static at a bit less than a 10 degree angle of heel. The important part is that the foil on the high ama is nearly clear of the water when the boat is not moving. The Wolf may have a bit more dihedral because it has movable ballast(crew) whereas the Test Model does not:
Self-Righting / Rightable Trimaran Doug Lord Multihulls 21 04-02-2012
10:32 AM
MPX-11 Very Small High Power Trimaran Doug Lord Multihulls 224 09-19-2011
09:29 PM
self righting motor trimaran jonr Boat Design 35 01-03-2010
11:56 AM
Small High performance Trimaran? Briggsm Boat Design 6 09-07-2009
10:16 PM
50'Self-Righting, 1200lb, Single Foil Proa-Rob Denney Doug Lord Multihulls 13 11-27-2006
10:57 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
