Doug Lord
Flight Ready
- Joined
- May 26, 2009
- Posts
- 16,679
- Reaction score
- 354
- Location
- Cocoa, Florida
Fire Arrow Foiler / MPX Foil System Testing and Development
This is a set-up I used on all my production RC models, but by the time I remembered it, it was too close to the first sail so I postponed installing it.The set-up allows any RC boat to point higher than if they use the "conventional" jib boom pivoted at about 20% of the chord of the foot aft on the boom. I used it in racing before I started producing models and it gives two or three degrees improved pointing. I'm hoping to get the Fire Arrow to tack on foils(almost impossible with her weight so I'm told) and the only way it will be remotely possible is to improve ,where possible, every aspect of her upwind set-up. The problem is adding the Hoyt jib boom after the fact and I may wait until I test the boat with the mast step moved aft(already done) to see if that is an improvement. So far, the only way I see to install the Hoyt jib boom involves surgery and will not be adjustable. But I'm thinking a lot about it so I may come up with a better solution.
The Hoyt jib boom acts as a vang as well as permitting the forestay to be on the centerline and changes the jib shape advantageously when eased. It really works well.....
Picture 4 shows the typical rc model set up and the way the Fire Arrow is set-up now:
click for best view---
