Old 02-26-2007, 10:36 AM
henrikb's Avatar
henrikb henrikb is offline
Rep: 116 Posts: 112
Headstay attachment on rotating mast?
Do anyone out there have some pictures of how the headstay attachment to a rotating mast use to be designed?
Any info is appreciated!
Henrik Borg
Builder of the IMS33 R/C
http://web.telia.com/~u21114029/
Old 03-07-2007, 09:34 PM
tspeer tspeer is online now
Rep: 1329 Posts: 1,523
I've seen a number of methods. Most have all three stays coming to a point just in front of the mast, attaching to a tang like is used for a conventional forestay.
One method uses a chain link shackled to the tang, to which are attached the three stays.
Another method is to have a double tang (forming a pair of jaws) to which is bolted the right-angle point of a triangular piece of stainless steel. The side opposite the point has three holes to which are shackled the other stays.
Tom Speer
Old 03-08-2007, 12:50 AM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
Mast Tang for Rotating Mast
Many smaller cats with rotating spars simply shackled all three (forestay & two shrouds) all together onto one tang.
I preferred to provide two separate attachment holes on the mast tang. The forestay was attached to a point that was closer to the face of the mast while the shrouds attached further out. This promoted a greater leverage by the windward shroud to firmly rotate the mast, since the forestay already had a greater angle and leverage, and would resist the rotation. This two hole arrangement necessitated the forestay hole as the lower of the two holes. (got an old drawing for my Firefly tri if I can find it)
I always found it was easier to put a rotation limiter at the base of the mast, rather than a rotation inducer.
RunningTideYachts.com
Distinctive Expedition Yachts
Old 03-11-2007, 06:04 AM
SPJ yachts SPJ yachts is offline
Rep: 10 Posts: 21
F/stay rotating mast
Henrikb,
we used some dyneema as a f/stay attachment at the hounds .
This with a positive main sheet angle on the boom and limited spanner at the mast should be ok
I used this system on a 12mtr racing tri and worked a treat, just have to check the dyneema every 6 months or so cause this material does not like load on too tight a bend for too long but im talking here in the tropics and i guess you are talking non tropics. (SWEEDEN)
good luck
SPJ Yachts
Rotating Wing Mast – theoretical discussion Man Overboard Sailboats 110 02-27-2011 05:55 PM
Carbon Rotating Wing Mast SouthernWing Fiberglass and Composite Boat Building 4 12-19-2010 09:40 PM
Rig Attachment kimper Sailboats 3 01-27-2007 12:59 PM
Stringer attachment johnsonmtz Fiberglass and Composite Boat Building 1 07-15-2004 01:53 PM
rotating aluminum wingmast Doug Carlson Sailboats 14 09-28-2003 01:52 PM
