  #61
Old 07-05-2012, 06:48 PM
Doug Lord's Avatar
Flight Ready
Rep: 1101 Posts: 7,439
Originally Posted by Corley View Post
Well Groupama2 won the last 5 ORMA championships and was easily the best ORMA of it's generation they prevailed against some strong competition so they must have arrived at a pretty good solution. The boat trims towards the rear which appears to be the prefered method when running foil assistance. It keeps the bows out and the boat resting on the rear full transoms with the bows providing plenty of reserve buoyancy. BP5 has over twice the waterline length to utilise, ORMA restricted boat length to 60' overall so you would expect the rearwards trim to be more noticeable with the shorter LOA. If I recall correctly some of the ORMA teams did try rudder or additional rear T foils but they were not a success.
I think in that video she was flying on the lee foil and planing on the back end of the lee ama. The ORMA(and the MOD 70's) were designed to have the ama foil support 70% of the boats weight. Whether a t-foil at the back end would reduce drag or not is still an open question-(I think it would but a better system might be two foils on the main hull controlling sailing angle and pitch and allowing for a wider platform). I love these videos.... Martin Fischer thinks it would be beneficial:
click-
yes, it is a Revolution
  #62
Old 07-05-2012, 08:27 PM
Corley's Avatar
Corley Corley is offline
epoxy coated
Rep: 619 Posts: 1,599
Doug, Interested in the trimaran in your picture did it get tested in different configurations and how did it go?
Multihull Yacht Club of Victoria
http://mycv-news.blogspot.com.au
blog/projects http://trimaranproject.blogspot.com.au/
  #63
Old 07-05-2012, 08:30 PM
Doug Lord's Avatar
Flight Ready
Unfortunately ,I haven't heard any more. I'll write Martin and check in.
  #64
Old 07-15-2012, 04:39 PM
Doug Lord's Avatar
Flight Ready
9 min Hydroptere video
Go here to see one of the most extraordinary videos of Hydroptere from the early days until now: Hydroptere-61 knots(70.15mph) Peak
  #65
Old 07-16-2012, 06:11 AM
HASYB HASYB is offline
Rep: 136 Posts: 218
Thanks Doug, best video of Hydroptere by far! Whow.. that boat behaves so gracefully through/on the waves. Like it a lot.
Laws alone can not secure freedom of expression; in order that every man present his views without penalty there must be spirit of tolerance in the entire population.
Albert Einstein
  #66
Old 07-16-2012, 06:55 PM
Corley's Avatar
epoxy coated
On the Sodebo website video page there are some really good videos. I quite enjoyed watching all the big french multis out for a bit of a joyride among the volvo fleet (they look a bit like birds of prey sizing up some juicy dinner) in the Lorient also the video of Ken Read out on Sodebo for a run.
http://www.sodebo-voile.com/carnet-medias/videos.html
Last edited by Corley : 07-16-2012 at 09:23 PM. Reason: Added gratuitous multihull racing superiority comment
  #67
Old 07-26-2012, 10:35 AM
Rep: 136 Posts: 218
Via crew.org.nz this nice video of mostly 8.5 class multi's.
http://www.youtube.com/watch?v=gOspv...layer_embedded
Albert Einstein
  #68
Old 09-04-2012, 05:00 PM
Doug Lord's Avatar
Flight Ready
Short video of Adrenaline( Gougeon tri) sailing:
http://www.youtube.com/watch?v=bQpTk...layer_embedded
  #69
Old 09-04-2012, 06:48 PM
Corley's Avatar
epoxy coated
Has Adrenalin ventured out much in Auckland? Certainly an interesting and beautifully constructed Formula 40.
  #70
Old 09-04-2012, 07:53 PM
Rep: 451 Posts: 1,843
Hardly seen it. I helped deliver it from Okahu Bay to Westhaven last year, no sailing unfortunately, rib lashed underneath instead. Last I heard, after all the talk of butchering the classic tri to make it local legal ( luckily only hot air and gas) was that Arnie Duckworth from West/Ad Tech has bought Adrenalin. He lives in Thailand and also owns the twin masted, unstayed wings, foil cat, foil in a central, movable box. Forgotten its name, well known.
  #71
Old 09-04-2012, 07:55 PM
Corley's Avatar
epoxy coated
Thanks Gary, I'm glad it wasn't butchered as it is an interesting boat in it's own right with a good history.
  #72
Old 09-04-2012, 09:48 PM
Timothy Timothy is offline
Rep: 192 Posts: 231
"unstayed wings, foil cat, foil in a central, movable box. Forgotten its name, well known." I think that would be "Happy Feet".
  #73
Old 09-04-2012, 09:58 PM
Doug Lord's Avatar
Flight Ready
Indeed it would be. HappyFeet uses a "bi-foiler" system similar in foil configuration to a Moth. However, the whole center pod with both foils moves port and stb. This system can allow the boat to fly a hull in lighter air than it would otherwise. Because it has a wand altitude control system, the foil can also add righting moment by pulling down instead of lifting up and it can do both automatically. Very innovative:
Great Multihull Video-happy-feet-foiler-site.jpg  Great Multihull Video-happy-feet-sa-3.jpg
  #74
Old 09-05-2012, 10:33 AM
redreuben redreuben is offline
redreuben
Rep: 179 Posts: 541
Is there an explanation why Idec/Sodebo don't have full length floats ?
Coz I just don't get it at all ?
  #75
Old 09-05-2012, 11:59 AM
Doug Lord's Avatar
Flight Ready
To save weight? They don't need the extra buoyancy of a longer hull with the foils. If you can have an excellent L/B ratio in a shorter, lighter ama it may be the way to go.
a new video site Çemberci Education 0 11-02-2009 04:13 PM
My favorite youtube video..... oscarvan Multihulls 4 06-15-2009 08:23 AM
Sailing Video(s) brian eiland Boat Design 41 05-19-2009 12:35 AM
Great sail, great gale, a little carnage and lessons learned CharlieCobra Open Discussion: All Things Boats & Boating 9 11-20-2007 01:49 PM
Great site here with great stuff... Gbenz Open Discussion: All Things Boats & Boating 7 07-18-2006 11:07 PM
