Old 09-13-2011, 08:28 PM
thedutchtouch thedutchtouch is offline
Rep: 39 Posts: 90
good idea or bad? catamaran made out of 2x Dave Gentry's Ruth?
what say you? http://gentrycustomboats.com/RUTH%20page.html obviously there would need to be a bit of extra framework where the crossbeams would attach (preferrably in a removable type of way), but any thoughts of this as a catamaran? it's already been done as a monohull http://capefalconkayak.com/jwboat.html
Old 09-14-2011, 07:34 AM
Rep: 1493 Posts: 7,447
It is rather fat for catamaran hulls. In waves there will be a lot of stress on the crossbeams.
Old 09-14-2011, 08:36 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
I have built many skin-on-frame kayaks, canoes and sailboats, it is a great way to build; lightweight, fast and much lower cost. I plan on trying it out on a catamaran as well sometime.
I would not just take a row boat and use it as a cat hull, too wide and too much drag as gonzo points out. IT would be better to take the lines off say a Tornado and adapt the skin-on-frame construction to the cat hull shape. It is not difficult to do, I have done it on a number of designs. The temptation is to make it much heavier than it needs to be, but I have found it is rarely necessary since the design tends to be fail-safe, it has mulitple redundancy. For example you can use stringers of 3/4" square, and gunwales of 1x2 for hulls up to about 18 ft long. Most will use much heavier material than this, but it is not necessary if you keep your stringers not more than about 8" apart max. Frames can be at about 12 to 16" spacing, even up to 24" if the boat is light displacement.
Two row boats lashed together to form a cat would be rather clumsy and slow. If you want to attempt that to use the hulls separately, use two canoe hulls or kayak hulls. I have thought of making a trimaran out of a long canoe and two small kayaks (all skin-on-frame), you load it up with camping gear and sail out to a remote location and set up camp. Than you can use the kayaks to go explore the local bays and estuaries. A cat can be designed the same way with two kayak or two canoes.
Old 09-15-2011, 06:25 AM
Rep: 39 Posts: 90
you are right, i was thinking out loud but it is pretty clear to me know that the RUTH hulls are poorly shaped for a cat. oh well
bad idea???? (10 ft 3point hydroplane) racing fan Boat Design 10 02-15-2011 07:37 PM
1978 formula good or bad idea? den44057 Powerboats 1 10-27-2010 03:36 AM
Good or bad idéa? nukisen Projects & Proposals 20 02-04-2010 11:40 PM
I'm new i need help! Junk rig bad idea good idea? Trevornew Sailboats 7 03-10-2009 07:55 PM
Starting big, a bad idea? matthait Boatbuilding 9 03-25-2008 06:47 PM
