| Front Cross Beam Tension Hello Fellas, Replaced the front beam in my cat, and it seems to be functioning as expected, and had it out in a few blows (35kts+ and 5 mtr seas) and the performance is as expected :-). (10 knots is now normal speeds for me :-)) But its a bit unnerving the flex of the forebeam in moderate seas, as the seagull striker on the forebeam loads and unloads in each wave (with the flex in the front beam being tangible to feel through my feet, but can't see it). Obviously with the forestay attached there will be flex, but I was wondering from the consensus of this group, what is the "preload" I should put on the front beam via the seagull striker turn buckle. I have played with it and I can bend the front beam down pretty easily, but Im not sure what the science of this is? BTW Mai Tai is a 11mtr shockwave with 3 * 5.5 mtr cross beams, with rear hard deck but no "cabin" so to speak. Thanks in anticipation Regards Brett
__________________ Brett +61 419 388 038 Crowther Shockwave 37" - 'MaiTai' Mark IV A-Class - 'Assagai' |
Have you managed to have the boat weighed, maybe when it was lifted?. If its gained a lot of weight over the years its certainly going to load up those beams. Regards |
| G'Day Bruce, Yup you got it in 1. I replaced the forebeam and removed/inspected the others. The crane driver gave me a sub 2000kg weight which is pretty good when the design weight of the shockwave 37 with "blisters" (WAHOO) for internal cabin is 2200kg (mine is the "racer" without the blisters). So the weight is within a normal range. I expected a bit of rig movement on the lee side, but there must still be an optimal tension. Do you know how much tension is supposed to be on the front "seagull" striker. Should I load it up and put a 25mm bend down on the cross member and then "straighten" it with the forestay... Ive done a bit of hunting on the net/library (yep a place with books!!) and can't find a reference to the science for determining the tension of the front beam. Cheers Brett
Probably not much point in going for more striker tension than will give you a straight forebeam under normal rig tension. Regards. |
| Eliseviv, Basically wire rope tension is a matter of elongation measurement, 1/19 wire rope will stretch then reduce to almost the same length but needs to be stretched a few times before it becomes more stable. Like mast rigging tension in cap shrouds, you are looking at stable tensions of 15 to 20% of the breaking load calculated (by the manufacturer) for the wire rope size, is is very constant at 1mm of stretch for 2000mm of wire (regardless of the wire diameter) being 5% of the breaking load, so 10% would be 2mm, 15% would be 3mm and 20% would be 4mm stretch. Remember that the wire diameter is inconsequential to the above statement, as all diameters are constant. It is not hard to measure this stretch with a digital vernier and a yardstick (2M is better).
| Hi Bruce and Samnz, Your coments are what i was after. Ill run up the front next time in in smooth water and look "along" the beam. and adjust from there...... Not sure Ill be up there while flying a hull though ;-). I think I probably have a straight beam now, but cant be sure till I sight along it. Bruce Ill look for my added half tonne... I guess if you add everything up it doesnt take long.....
| Hi Landlubber, While not what I was after, a really good bit of information to store in the memory banks, its something Ive needed to know in the past, and for sure will again in the future. Cheers
| Cross beam material - 11mtr racing cat | Eliseviv | Multihulls | 7 | 02-02-2011 03:29 PM |
| Internal Cross beam/sleeve clearance | sail | Boat Design | 1 | 10-12-2009 10:53 AM |
| Carbon cross-beam design ? | Erwan | Fiberglass and Composite Boat Building | 0 | 01-01-2008 07:13 AM |
| Forestay tension | nemo | Sailboats | 0 | 02-11-2004 04:59 AM |
| rigging tension | Lew Morris | Sailboats | 1 | 09-27-2001 08:18 PM |
