Old 10-27-2008, 01:48 PM
Daniel Noyes Daniel Noyes is offline
Rep: 32 Posts: 36
Free 16' Trimaran
I have a experimental, home built composite Trimaran hull. has been outside for several yrs and in need of reconditioning, 16' center hull, 8' planing type akas, 8ft wide, will likely need to be cut into two or three pices for transport. biplane rig (trifoiler inspired) rig is widsurfer masts, booms, sails (not included) supported by foam/glass tripod masts. free to a good home, well built but not being used.
Dan
http://dansdories.googlepages.com
Old 10-29-2008, 10:09 AM
eponodyne eponodyne is offline
Rep: 150 Posts: 322
If I could, I would! Have you let everybody on WBF know about it? Oh wait it's made of The Other Stuff.
Old 11-11-2008, 01:15 PM
Rep: 32 Posts: 36
Free 16' trimaran photos
dan
click on "photos" at
Old 11-11-2008, 04:26 PM
Chris Ostlind Chris Ostlind is online now
Mike Nelson Protege
Rep: 413 Posts: 1,528
Dan's free trimaran
Dan,
What is going to keep that boat from rolling offwind and forward along the vector lines into a pitchpole?
I would think that the design would need substantial pitch/role resistance well forward, OR a seriously reduced sail area, in order to deal with the forces present while sailing.
Chris
Chris Ostlind
Lunada Design
www.lunadadesign.com
Old 11-12-2008, 11:01 AM
Rep: 32 Posts: 36
The three times I had her sailing she showed no signs of pitchpoling or rooting, none. the windsurfer rig develops power so low that there is very little lever arm to initiate a pitch pole. I initially envisoned the sailor spending most of his time sailing from the deck on the rear ama sliding on it to adjust trim like a sliding seat on an international canoe, but when I sailed in moderate winds but only with one sail I spent most of my time about amidships... the bow is extremely bouyant and resists any forward pitching forces easily.
The Tri was designed for use with a ventilating front hydrofoil, a flat plate that generated lift like a foil untill it broke the waters surface then ran along the top as a highly efficient planing hull and also controlled the attitude of the aft hydrofoil, that remained submerged and carried 80% +- of the weight of craft and sailor... 8 yrs. later I have yet to build the foils.
so
free to a good home
Dan
Old 11-17-2008, 01:56 PM
Rep: 32 Posts: 36
I have sailing photos available via Email for interested party...will try and get them on line soon
Dan
Old 11-26-2008, 11:02 AM
Rep: 32 Posts: 36
last call
any one interested in a head start on a small tri. could also be used as a paddle board for fishing or messing about on a lake.
Dan
photos at
http://www.flickr.com/photos/dansdor...7608879286433/
Old 11-27-2008, 02:47 PM
rayaldridge's Avatar
Rep: 134 Posts: 246
Dan, I'd love to have it, though I might build longer floats-- but I live too far away, in NW Florida.
By the way, your dory is beautiful, and you've taken some very effective photos of it.
Ray
http://slidercat.com/blog/wordpress
Old 12-08-2008, 05:08 PM
Rep: 32 Posts: 36
Hi Ray
Yes the tri is still awaiting a good home, and yes the hulls are short for a traditional tri, the idea was for the akas to be like little stabalizing floats while the sailer used his weight to windward to really counter the healing moment of the sails(almost like floats on a sailing canoe), that way the akas could be much smaller and lighter, not responsible for floating the whole contraption up on one hull.
I think the shallow rudders you mentioned on WBF will work fine on your cat, mabey even better than on a mono hull because your leward hull will actually be deeper than the static waterline by quite a bit alowing for more than enough rudder controll, the nice thing is these shallow rudders are so much simpler than a kickup (almost nothing to fiddle with or break), they can also be built pretty rugged.
Dan
Old 01-09-2009, 09:36 AM
Rep: 32 Posts: 36
Tri went home with a fellow from Sunapee Nh last weekend.
Dan
16' drft boat pduhglas Wooden Boat Building and Restoration 1 08-02-2008 01:34 AM
Catboat across the Atlantic? (16') Seafarer24 Sailboats 31 04-14-2008 01:08 AM
Help w/ a sweet 16' thoredcor Inboards 1 06-23-2007 10:33 AM
FREE! 31' Sea Ray Sedan Project FREE! drs3317 Marketplace 10 07-17-2006 12:37 PM
16' supersidewinder molds ohio builder Marketplace 0 09-26-2004 11:22 AM
