Old 08-13-2008, 06:58 AM
steve.b steve.b is offline
Rep: 10 Posts: 16
Formula catamaran hull shape
Hi
In the process of designing a Formula 16 type catamaran.
What sort of Cp values should i be aiming for and where should the LCB be?
thanks
Old 08-14-2008, 03:29 AM
waynemarlow waynemarlow is offline
Rep: 72 Posts: 96
Steve tried to send a P message to you Ref the F16 design but are unable, check your profile.
Thanks
Old 08-14-2008, 06:32 AM
Rep: 10 Posts: 16
hi
thanks for trying, i cant receive PM's yet as i haven't posted enough on the forums.
It should be working now though
thanks
Old 08-14-2008, 06:40 AM
Rep: 10 Posts: 16
hmmm, still not working..
(i need to make a couple more posts)
i am designing the boat in maxsurf, but only designing one hull as i want them to be symmetrical. is there an easier way to get 2 hulls in maxsurf (but keep them symmetrical)?
Old 08-14-2008, 06:48 AM
Rep: 10 Posts: 16
if PM still isnt working, you can drop me an email on:
steve(at)l26racing.com
(obviously replace (at) with @, done for spam reasons....)
thanks again
Old 08-19-2008, 08:27 PM
CTMD's Avatar
CTMD CTMD is offline
Naval Architect
Rep: 117 Posts: 196
to make a symmetrical cat in maxsurf.
1. Model half the hull.
2. Flip-Copy the hull around the centre line
3. Move the two surfaces out to the new hull CL
For the LCB do a quick weight estimate. There is quite a bit of data over at catsailor on mast weights etc. and then put the LCB in the right place.
Prismatic is a secret and will vary based upon design principles. The DS16 is approx .55 when flying a hull.
Chris Tucker Marine Design
Your Boat Your Way.
www.ctmd.com.au
Old 08-20-2008, 04:36 AM
Rep: 10 Posts: 16
Great, that has got me in the right direction.
thanks
Old 08-20-2008, 04:50 AM
CTMD's Avatar
Naval Architect
Rep: 117 Posts: 196
Steve,
I should point out the DS16 is optimised for sailing one up. So your numbers will probably vary.
Your Boat Your Way.
www.ctmd.com.au
Catamaran forebeam shape AndrewK Multihulls 18 09-26-2007 07:01 AM
Hull Speed Formula , Pointing, and Twin Keelers Michael D Sailboats 3 04-06-2007 03:16 PM
Which Hull Shape? monrosm@shrewsb Boat Design 8 08-10-2006 10:54 AM
Transom vs. V Shape for Catamaran Stern Hull Free Pirate Boat Design 15 03-17-2005 06:16 AM
Hull Shape mrbrown Boat Design 1 08-09-2004 11:24 AM
