Old 04-03-2017, 10:12 AM
Pammie Pammie is offline
Rep: 10 Posts: 4
F28 cat pitchpole resistance
I designed a F28 cat and would like to hear your opinions about it.
It should be able to comply with ISO12217 stability cat A. Base is a Nacra Infusion like design as these are known for resistance to pitchpoling. I scaled it to 8,5 meter (length and width). Width is then 0,77 m. Height was extended to 1 meter height above waterline. Further I decreased rocker line as Nacra is ideally sailed on one hull and a ocean racing cat is not. (BcB = 4,8 m)
Stability calculations showed it was about 20% short of minimum requirements (which is cat B). Therefore I extended the hull width to 1 meter with special attention to the waterline width (about 0,7 m). Wetted area is 5,8 m2.
This was just enough to match cat A pitchpole stability.
But... I'm not quite happy with the hullform. Semicirculair line is quite some distance above waterline, and wetted area could be smaller (4,7 m2 for semicirculaire tube with pointy ends?) Further decrease rockerline? (at what cost?)
Some hints would be appreciated.
F28 cat pitchpole resistance-f28vs4.3.jpg  F28 cat pitchpole resistance-f28vs4.31.jpg  F28 cat pitchpole resistance-f28vs4.32.jpg
Cat hull resistance change with heel? DennisRB Hydrodynamics and Aerodynamics 49 04-15-2016
03:12 AM
Catamarans: 60ft 1978 v shaped hull cat vs a modern 38ft cat biglittlefish Boat Design 15 03-28-2015
11:06 PM
Cat moulds for sale to build a 6.5metre rib cat very nice joseph sigley Boat Molds 2 06-24-2013
01:24 AM
Cat's Hulls resistance to leeway Erwan Hydrodynamics and Aerodynamics 12 02-19-2012
12:11 PM
Rig handling: Cat Ketch, Cat Schooner, Sloop, Cutter Seafarer24 Sailboats 8 05-30-2006
10:06 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
