| DSS for "Foil Assist" on Multihulls? Its ocurred to me that the DSS(Dynamic Stability System) horizontal sliding or pivoting foil might work for foil assist on an ama and be shallow draft as well. Could open up foil assist benefits for multihull cruisers concerned about the draft of other systems. And for speed freaks as well... http://dynamicstabilitysystems.com/#/profile Interview with Hugh Welbourn with good questions and answers about the system on monohulls; http://www.harken.com/Interviews/DynamicStability.php |
| An intriguing concept, for sure. Gain a bit of righting moment, increasing with speed and heel, without any extra ballast. It looks to me like it could be worthwhile for racers, esp. midsize to large monos. For a cruising mono, it may work, but I'm not sure you'd see the same benefit with a cruising rig as you would on an overcanvassed racer, apart from maybe being able to push a bit harder before reefing. You'd have to take the ability to use this foil into account right from the conceptual design stage, when deciding how the boat is expected to be sailed. I'm not clear on what the benefit to a cruising cat or tri would be, though.... since neither can heel significantly without flying a hull. But using it as a swim platform when at anchor would be kind of cool.
| A cruising multi might heel enough to have this foil contribute to RM(it might not need to heel?). But what a simple, shallow draft way to power up a small tri or cat! But I agree the boat would probably have to be designed for it from the get go. Something to think about.... |
| DSS for multihulls I'm looking at this again because of my "sudden" realization that curved foils can reduce the righting arm and therefore the righting moment on racing multihulls that use them. Curved foils were originally intended as rule beaters but on a cat like Alinghi they would have reduced righting moment(on a boat already narrow compared to USA) while using a properly implemented pivoting(like a centerboard) horizontal foil would have increased RM as well as reduced wetted surface-without violating any rule.The tri is so wide that the slight reduction in RM is meaningless. Whether the trade off in overall L/D would have worked or not is not easy to say but I'd bet on it. There would be a slight weight gain and each hull would still need a vertical foil(lee daggerboard designed to be vertical when the windward hull just clears the water*). The lifting foils are 100% retractable and easily adjustable for angle of incidence. The biggest problem I see is keeping the horizontal foil immersed enough to avoid surface proximity drag.... *Alinghi's daggerboards were canted toward the cl of the boat at the bottom about 10 degrees-this would be counterproductive in combination with DSS-they would need to be angled outboard at the bottom so that they were vertical when the windward hull just cleared the water-allowing for minimum wetted surface.
__________________ yes, it is a revolution ---"So (yet) another new world begins." Andrew Hurst, editor of Seahorse magazine, August,2011 |
| DSS tri application The DSS does seem to have some credibility. The problem for a tri though is that you would like a relatively long foil for efficiency and it won't fit inside the hull. I think I have a solution that is an improvement for all DSS systems and also lets it work on a tri. The foils they show are essentially a horizontal asymmetric DB. Instead, you want a CB. On a tri the foil will easily pivot into the hull for light air and docking. A shaft from the pivot can go up through the hull to a lever on top of the hull. Simple, clean, efficient. If you can find the right sized tri you could ese the boards out of an M17 scow. In a class like the NZ 8.5M you have a beam limit. There I think I would accept that you want maximum beam for the amas, so I'd put the foils on the insides of the two amas. I'd probably set up angles so that with two hulls flying the leeward hull is vertical and the foil provides lift and lateral force, like the curved foils on USA-17. And because it's disclosed here, only I can patent it, I have a year to do that and I'm not going to, so it's open to anyone. I of course will modestly call it a Raymond Foil. Fortunately, I'm going to finish writing this and immediately send it. If I let is sit for a little while I'm sure I'd take out the egotistical paragraph above, which would certainly reduce my potential embarrassment and the readers potential amusement. |
| Raymond foil--pardon me but I like Lord foil....or just DSS for Multies! Quote:
Did you read my post? Besides my post(for multihulls), the "horizontal centerboard" idea was already conceived of by Hugh Wellbourn and is illustrated on a Wally on his site. Edit: "centerboard" type DSS foil: Go to the website, post#1; click on designs-superyachts-DSS100,then the thumbnail image on the right(of the two on the left of the screen and(whew!) you should see it). Glad you think it will work for multihulls-how would you avoid surface proximity drag? -------------- Quote:
From Ocean Navigator: How would DSS foils be fitted to a voyaging boat? The 27-foot DSS test boat has an internal tunnel that runs from one side of the hull to the other. On a voyaging sailboat, the options would presumably be greater, depending on the size of the vessel and its configuration. Rather than a tunnel running across the beam of the boat, it would be possible to build foils into individual tunnels on either side of the boat. Welbourn comments via email: “The choice between individual P&S foils or the straight-through foil system can depend on several aspects of the overall design of the boat in question. On many typical medium displacement boats then the transverse foil system will disappear under the floorboards and so not impinge on any internal arrangements. This is the simplest and lightest solution, but sometimes there is a case to be made for separate foils — in this case typically they fit outboard of the bunk fronts so have no impact on the saloon area.” http://www.oceannavigator.com/ME2/di...2BE20418A962A7
| Pivoting foil It's amazing, how did you copy it from me before I wrote it? |
| CMD "project Zeus" VS VOLVO "IPS" | gerard baladi | Pod Drives | 13 | 09-10-2007 10:23 PM |
| Boat "workshop" including a "testing tank" | zmfmd | Open Discussion: All Things Boats & Boating | 0 | 08-08-2007 05:43 AM |
| Westlawn ? "Lite" versus "Module 1" | MikeT | Education | 2 | 10-10-2006 01:13 PM |
| "Free" 3D modeler "similar" to Rhino | CGN | Software | 0 | 05-14-2006 11:56 PM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 03:03 PM |
