Old 02-18-2009, 10:54 AM
robherc robherc is offline
Designer/Hobbyist
Rep: 102 Posts: 433
Originally Posted by daiquiri View Post
Hi Robherc,
Just one consideration/question - if your cat is not intended for speed, then why did you choose to give it wet transoms? It will add resistance in displacement speed range. Or was it just a necessity to add volume aft and keep the draft as shoal as possible, for a given weight?
Cheers.
Actually, the transoms are wet because it was a 2 hour redesign from a canoe stern that just didn't have the properties I wanted. I'm not completely done fiddling with it yet, and I'm probably going to raise the transoms another few inches. I'll likely end up leaving 1"-2" (2.5-5cm) of the transoms wet for extra aft buoyancy as you guessed, but I think I can trim it down more than I already have.
....just my $0.02, take it or leave it.
Old 02-18-2009, 11:02 AM
Designer/Hobbyist
Rep: 102 Posts: 433
*****oops*****
...I just looked at that linesplan again....it looks like I posted the WRONG PLAN...the posted plan shows an 18" draft, 30' LOA cat (that I designed in 15 minutes, for a diff. thread), my boat will be 9" draft and 22'6" LOA...here is the correct linesplan (with MUCH less wetted surface on the transoms).
Old 02-18-2009, 05:32 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Originally Posted by sigurd View Post
I found it in his folder at proa_file yahoo group.
There are other spreadsheets there to look at as well.
Thanks Sigurd, I'll have a play with the spreadsheet.
Regards
Fanie
Water ! Just gimme water !
Designing an amphibious flood response vehicle? cardboard Boat Design 26 12-03-2007 04:57 PM
twin keel 2' draft instead of single 7' draft on 65' yhxaig Projects & Proposals 3 11-12-2006 06:25 PM
Response from EWB-USA and TRB CDBarry Post-Tsunami 1 04-14-2005 10:09 AM
Mast bend charasteristics ( dynamic gust response) patrik111 Sailboats 5 08-01-2004 02:23 PM
Bilge Depth cklanac Sailboats 10 06-28-2004 05:32 PM
