| Downsizing chain Greetings to all; I am looking to replace my manual windlass ( ughh!) with an electric one on my 42ft Piver. I have 80ft of 5/16th now and I want to downsize to 1/4" but have 150ft of it and then 250" of nylon rode. Is this feasable in terms of holding power? Say in 40 knts of wind? (most times it is around 10 or less) Kelly. |
| Why would you down size? -Tom |
| because I have a manual windlass and I could handle 1/4 inch easier...i was just wondering. |
| No way the 5'16 is already on the light side for a 40footer. We have it on our 38 footer and would only go up rather than down. 6mm - 0.8 kg/mt - Break Load 1630kg - SWL 400kg 7mm - 1.0 kg/mt - Break Load 2550kg - SWL 630kg 8mm - 1.4 kg/mt - Break Load 3200kg - SWL 800kg Stay with the 8mm if you want to sleep well. cheers Phil |
| Thanks for all the replies. Yeah, it appears the consensus is to stay with 5/16th. Looking for a decent used windlass ![]() |
| Darn it how can you stay in shape using a windlass? I never use a windlass, I don't have a windlass and I use more than a boat length of chain. So when you get that electric let me know about your manual one, the waters up North can be deep........... |
| I have a manual winch on Kankama and like it. It has anchored over a thousand times and it does really well. Light and gets me in a bit of sweat if I go hard at it. The specs are from the Muir site. MANUAL VERTICAL VMC500 VESSEL LENGTH 6 - 12m (19 - 38 ft) ___________________________________ POWER SUPPLY (DC) Manual ___________________________________ MOTOR (Watts) N/A ___________________________________ MAX LOAD 227kg (500lb) ___________________________________ WORK LOAD N/A ___________________________________ AMPS WORK LOAD N/A ___________________________________ RECOVERY RATE 36cm/revolution (14.5"/revolution) ___________________________________ CHAIN SIZE 6 - 8 - 10mm (1/4" - 5/16" - 3/8") ___________________________________ ROPE SIZE 12 - 14 - 16mm (1/2" - 9/16" - 5/8") ___________________________________ NET WEIGHT 6.5kg (14lb) ___________________________________ |
| Thanks catsketcher, I like the low weight. |
| Locating Chain Plates | Bomber | Boat Design | 9 | 01-22-2010 04:23 PM |
| Compression, downsizing of pictures, need help! | apex1 | General Computing | 15 | 02-05-2009 01:17 PM |
| 3/8 HT Acco chain | nero | Marketplace | 0 | 07-24-2008 08:36 PM |
| chain plates | Scofield | Sailboats | 3 | 03-31-2008 01:56 PM |
| lining chain locker | Archive | Boatbuilding | 9 | 06-06-2006 08:47 PM |
