| Double diamond spreader conversion G'Day from Oz I'm now more than half way to building a (modified) Trinardo 6.2 metre trimaran with a new main hull and where the ama volumes have been increased by a factor of 5 - more on this later. For now, I'd like input from you experts on beefing up the existing A Class mast into something more suited to the tri. No. I can't afford a new mast - Being semi retired, labour is readily available, cash is not. The existing A Class mast is only a 150 X 75 mm 1.5 mm thick section and is relatively unstayed (see picture) and being over 9 metres long with only a single set of spreaders one-third of the way up, it is hard to know why it never broke. What is proposed is more like the attached picture, with double diamond spreaders and associated stays. The radar dome in the picture will be replaced by a tri-lens radar reflector) Also attached is a MS Word file showing the modifications and dimensions applied to the existing mast. I shall also add an epoxy/glass sleeve (as suggested by Richard Woods in a former thread). Comments please - especially on my suggested positioning of the new top tang and new upper diamond spreaders Thanks Alan |
| I find those diamond rigs complicated and expensive. They are great selling tools though. On a trimaran you have a very large beam. It is cheaper and simpler to add shrouds.
__________________ Gonzo |
| Why two diamonds ? When the mast is loaded in compression , the diamond keeps the mast in column. Since you are changing the head stay geometry by raising and thus increasing compression why not simply relocate...raise and lengthen.... the existing spreader to achieve the correct shroud angle then add a diamond stay attachment near the new headstay ? Perhaps use the the new rigging attachment hounds compression tube to double as the new halyard sheave axle or make the new shroud tang double as the new headstay attachment. Two panels, diamonds, will work ... one panel should also work and with less gear aloft. |
| Vang Spreader | Doug Lord | Sailboats | 14 | 11-19-2010 06:46 PM |
| YW Diamond Keelboat. | DennisRB | Sailboats | 40 | 08-17-2010 10:36 PM |
| Spreader lengths | Gashmore | Boat Design | 0 | 08-13-2008 06:38 PM |
| The Diamond Line... | Sean Herron | Open Discussion: All Things Boats & Boating | 2 | 05-28-2007 10:55 PM |
| Spreader Lengths | Oats and Beans | Boat Design | 3 | 11-25-2004 05:25 AM |
