Old 03-31-2009, 05:05 AM
jedkins jedkins is offline
Rep: 9 Posts: 26
Does 25% Larger mainsail = 25% more power?
Hi,
I have a 6m Kurt Hughes designed tri with a 9 m mast with mainsail of 16.5 sq mtr. (Luff is 8.2 m and foot is 2.6 m) The boat is under powered for racing and barely buries an ama upwind even in 25 knots of wind with the main fully sheeted in. And helm remains very light.
I am considering increasing the main sail size by abt 25% which can be accomplished by extending the foot and having a larger roach and by also having a big wide flat power top.
The mast /rigging is strong enough but would this 25% extra sail area give me 25% more POWER.? Would I be wasting my money? Any expert advice from someone who truely understands the dynamics of how sails work would be very welcome.
Old 03-31-2009, 07:12 AM
daiquiri's Avatar
Engineering and Design
Rep: 2574 Posts: 2,731
The relationship between sail surface and aerodynamic forces generated by the sail is not linear if the geometric similarity is not maintained when comparing two different sail designs. That's because other important properties are modified by extending the sail towards the leech - like aspect ratio and twist, for example.
Maybe you could try playing a bit with this nice applet:
http://www.wb-sails.fi/news/SailPowe...lPowerCalc.htm
Old 03-31-2009, 04:21 PM
Rep: 700 Posts: 691
Lower aspect helps downwind
Going longer on the foot rarely helps upwind performance. As your boat will spend an awfully large amount of its time with the apprent forward of the beam this would not be a great way to go. You will also increase weather helm and your light helm may end up as lots of weather helm. On top of this the tacking performance will probably drop.
It is probably best to give Kurt Hughes a line and ask him. He will probably recommend you go larger overall and keep the rig balanced or leave the thing alone so he doesn't get publicity from capsizing tris - 6 metres is very small and as stability is non linear is much more likely to capsize than a 7 or 8 metre tri. The factor of safety for your boat is probably higher than for a larger design.
cheers
Phil Thompson
Old 03-31-2009, 04:48 PM
bill broome bill broome is offline
Rep: 48 Posts: 102
you bury the ama in 25 kts, and you want more sail?
you've got enough. but in lighter air, maybe not- can you hang out a bigger jib? a mast head genny?
mb a longer foot would help a little, by reducing twist and holding the top to work.
Old 04-04-2009, 07:42 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Originally Posted by jedkins View Post
I am considering increasing the main sail size by abt 25% which can be accomplished by extending the foot and having a larger roach and by also having a big wide flat power top. ...
Do you have a screecher? They can be used as an oversized jib upwind in light air. They can be very effective in under 6 kt of boatspeed.
You might consider a taller rig for racing. The taller rig will have less drag due to lift, and it would be a way to add area that can be reefed back to the original dimensions as the wind picks up. Plus, it will retain the balance of the existing rig.
Tom Speer
Old 04-10-2009, 04:04 AM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
Look at multihull ratings
A little late but...
Multihull rating systems give good information about performance of multihulls:
- multi2000:
http://www.ctcnederland.nl/Pagina.ph...=7&paginaid=45
- texel:
http://www.multicoques-habitables.co...%20anglais.pdf
The principle of mulltihull rating R is:
R = L^0.3 * SA^0.4 / D^0.3 , where
L is the length of waterline or hull
SA is the sail area
D is displacement
So if you increase your sail area by 25 %, your speed will increase by 1.25^0.4 or about 9 % assumed your multihull has enough righting moment.
Only shared knowledge can grow.
Old 04-10-2009, 11:30 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Everyone is always referring to bigger sails. More sails but watch the mast loads.
How about something that wil pick the boat up instead of trying to sink it. Lift means less drag and more speed.
How about using a kite as an extra sail. It will make lift, you can adjust the lifting position to where it gives the best stability and you're not limited in size other than what you can handle.
More wind is higher up too. Then if you want even more how about a second kite on the same line that sits below the first, kind of like adding a second engine in tandem.
No I don't know either, but it is possible.
Regards
Fanie
Water ! Just gimme water !
Old 04-12-2009, 09:52 PM
Originally Posted by Fanie View Post
...Lift means less drag and more speed....
Not necessarily. There's a drag penalty for the lift, too, and it can be substantial. And the drag due to lift is inversely proportional to the square of the apparent wind speed, so if you're not sailing fast the drag due to lift is even worse.
Tom Speer
Old 04-13-2009, 05:34 AM
Fanie's Avatar
Fanie
Hi Tom, you'r right, there are many variables.
I watched a small cat screetching down the shore on one of our dams a while back, it was actually going really fast. The only problem this guy had was when his leward hull burried a certain amount it looks like he dropped the anchor out. If he could have added some lift on his rig...
I experienced the same on a windrider. At 8 kn it buries the one amas completely and the center hull goes under as well, the spray over the windscreen makes it difficult to breathe. Adding a jib that makes lift greatly changed it, 12kn and you can still breathe.
Regards
Fanie
Old 04-18-2009, 03:56 AM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
On almost all sailboats if you are serious about performance increases it is better to increase the mast height than increase the boom. This will give a higher profile sail resulting in a much more significant speed gain than a longer foot. You also want to increase the roach of the main as much as possible to again increase the aspect ratio of the sail. Though this may be limited by standing rigging (though a kicker is an option in this case).
Either way you are looking at doing some pretty major changes to the boat and sinking a lot of cash into trying to redesign a rig. Instead you may just want to look for a boat with performance numbers closer to what you are looking for.
Mainsail sheeting bntii Sailboats 12 07-22-2008 02:45 PM
Split Mainsail. Has this been tried before? Omeron Sailboats 21 11-18-2007 10:27 AM
Upgrading to larger boat. Mychael Sailboats 3 11-06-2006 01:24 AM
Larger mainsail Guest Sailboats 2 09-20-2003 06:48 PM
gap between mainsail luff and mast dionysis Sailboats 5 08-29-2003 09:00 PM
