Old 02-04-2010, 08:47 AM
lane lane is offline
Rep: 10 Posts: 18
Design help needed, Parallel Rig on a Trimaran?
Attached is a pic of my Hobie 18 based trimaran. With the current Hobie 16 rig, performance has been good and I feel that she can carry a lot more sail.
I now have two complete Hobie 16 rigs to play with and am considering a parallel rig setup with one mast on each ama. The boat is 16ft wide and I was thinking about putting the mast steps just inboard of each ama.
1. What kind of concerns would I have as far as stress on the beams?
2. Where should I attach the stays?
Lane
Old 02-04-2010, 02:32 PM
Rep: 457 Posts: 1,404
You can freestand them through floats - or you can check out MacApine Downie's setup on Crossbow 11, or Ketterman's Trifoiler; on each example there is a tension/compression spar support across to each hounds position, plus crossed triangulation of the inside rigging shrouds.
Old 02-05-2010, 09:55 PM
Munter Munter is offline
Amateur
Rep: 100 Posts: 223
The challenges to this rig configuration extend well beyond just holding the mast up. Leech tension on most small cats comes from high mainsheet tension with the traveller down to leeward. If you mount the masts on the outboard hulls you will need to come up with a way of getting leech tension on the leeward rig because you presumably won't have a traveller extending the beam even further out to leeward to pull it tight for you!
Notice how a lot of the biplane rigs are either sailboard style or have a fixed rigid boom in an attempt to address this problem? Combining a sailboard boom with a rotating mast might be a challenge but that wouldn't be insurmountable.
Cole 43 Rumrunner II - An Australian classic
My home efficiency/renovation blog
Can you parallel two alternators? IamBarry Electrical Systems 9 09-24-2009 11:45 PM
hartleys lively 28 trimaran info needed scottscotland Boat Design 8 09-08-2009 12:46 AM
Advice needed on sailing rig GKolln Sailboats 2 08-30-2009 07:18 PM
Batteries in Parallel seanform OnBoard Electronics & Controls 6 04-27-2008 12:50 AM
Trimaran design help needed 40' LOA eightwgt Services & Employment 6 05-16-2004 12:14 PM
