Old 04-18-2005, 08:46 PM
SAILFASTtigre SAILFASTtigre is offline
Rep: 10 Posts: 9
design of a fast 27 catamaran
Hi everybody.
i am designing a 27 foot sail catamaran to sail steady trade winds, long ocean swells.
I have completed preliminary hull lines, and the hydrostatics for one hull are:
Displacement 1 tonne
Volume 34.44 ft^3
Draft to Baseline 1ft 4.99in ft
Immersed depth 1ft 1.05in ft
Lwl 26ft 11.92in ft
Beam wl 2ft 10.01in ft
WSA 78.41 ft^2
Max cross sect area 2.01 ft^2
Waterplane area 58.25 ft^2
Cp 0.634
Cb 0.414
Cm 0.696
Cwp 0.761
LCB from zero pt -8.67in ft
LCF from zero pt -1ft 11.3in ft
KB 1ft 0.57in ft
KG 1ft 4.99in ft
BMt 10.15in ft
BMl 75ft 2.45in ft
GMt 5.74in ft
GMl 74ft 10.03in ft
KMt 1ft 10.72in ft
KMl 76ft 3.01in ft
Immersion (TPi) 0.141 tonne/in
MTi 0.221 tonne.ft
RM at 1deg = GMt.Disp.sin(1) 0.01 tonne.ft
Can somebody comment on these? I will be glad to share the computer file design with anybody willing to collaborate,
best regards to all,
david
Old 04-18-2005, 09:39 PM
oldsailor oldsailor is offline
Rep: 10 Posts: 12
I see your hull L/B ratio is 9.5 :1, which is a good fineness ratio for a cruising mulltihull, but what is your beam overall. For the waters you are considering sailing in it should be 15' wide, or approx 12' wide on hull centrelines.
Cheers. Oldsailor.
Old 04-18-2005, 11:03 PM
Rep: 10 Posts: 9
right.
i was looking for a commentary on the hull hydrostatics. what about the LCB and LCF?
would you like to check a 3d cad image?
regards,
david
Old 04-19-2005, 01:36 AM
Rep: 10 Posts: 12
SORRY DAVID.
I am not "UP" on hydrostatics, but if your are able to post a 3 view of your design I would be happy to see it.
Cheers. Oldsailor.
Old 04-19-2005, 05:27 PM
sharpii2 sharpii2 is offline
Rep: 419 Posts: 854
Hi S.F.tigre.
Being a graduate of THE LANDING SCHOOL I am embarassed to admit I know what only half those numbers mean.
What I think would be helpful is a list of design objectives. Such as:
a.) intended use. Is it a huge daysailer? A weekend cruiser? or is it expected to cross an ocean?
b.) payload expectations. How much do you want it to be able to safely carry?
c.) performance expectations. From your handle, I'll asume you want it to be as fast as possible. But there is always a price for speed.
d.) budget limitations. Even the richest man in the world has to live on some kind of budget. (maybe by successfully doing so in the past is why he is so rich.)
And these are only the ones I can think of off hand.
As you can see, they all relate to one another.
During my final months at the school, we were to do our 'final project'. With in certain limits, of course, we were allowed to design to our heart's content.
One other conditon was that we were to write a brief summery on what the design was to be about along with a freehand sketch. I handed in a bunch of numbers that were mostly about the dimensions of my new boat. It was to be based on a famous American workboat called a 'cowhorn'. It was to be over 42ft long.
A day later, my summery was returned with what in effect said 'unacceptable' written on it. I couldn't figure what the old guy wanted, so I asked him.
My next summery was over three pages long. It started out with a simple purpose, to cross a great ocean. Then the 'conditions' multiplied like rabbits. The new boat I sketched was almost eight feet shorter than the original and slightly less than 60% its displacement. And it handily met all of my objectives.
That summery got a quick green light, along with a wink, from the old guy.
Let me suggest that you make up such a list. Make it as short as you can but as long as you have to. And put the things you care about the most at the top of the list. In the design process a lot of things on the list are often going to end up being abandoned, so its a good idea make sure those things are not the things you really want.
Just for the fun of it, why don't you post this list so everybody can compare it with the numbers you have already posted.
Good luck on your project.
Bob
Old 04-20-2005, 02:35 PM
Rep: 10 Posts: 9
design objectives 27' cat
Right Bob, thanks for your reply, there you go:
Island hoper, dismountable –avoid marina and insurance expenses, hurricanes-, fun –I mean fast-, but able to deal with 6-8 long swells –not steep-, 20-30 knots.
Trailerable, meaning after dismounting three cross beams –standard aluminum extrusions-. Three people needed. Can be shipped in specially purposed built crate and or 40’ container –perhaps mast has to be spliced.-
Fast, so light, -wood composite or foam but vinylester to keep it cheap- round sections at the sterns with lightly swept up buttocks, fine bow sections. Prindle, f-18, … shape but a little more conservative-for weight carrying, without creating under wing wave resistance. – weight/performance compromise - High cross beams, meaning not necessarily in the same plane as the deck, bit higher. Cutter rig with furlers –only profurl-, full batten main with lazy jacks and reefing system –harken style-, for easy single handling. Water proof vhf and chart plotter, for Safe Island hopping. Able to fly a hull upwind or reaching for performance, but only enough to clear the water, no risking it here, mainsheet in hand… meaning also one hull supports full displacement.
No living quarters. Only storage. Maybe a bunk without standing headroom and a small copkit with swept up deck for boat handling in bad weather. Open deck, trampoline, maybe a small deck part in center, between the two cross beams. At anchorage boom can be used as a support for tent or sun cover. Electric Autopilot –piston-, simple steering, beach cat style.
No crossing oceans here people…
No engine –maybe a small long leg outboard -, small battery bank for lights and instruments charged with solar panel or air marine wind generator.
Small flexible 2 water tanks –maybe connected, hand pump transfer for water ballast. Barbecue on stern, fishing poles racks and a small bikini in aluminum tube.
Dagger boards for upwind performance and kick up rudder for beach landing or unseen reefs, uppssssss.
Surfboard or windsurf rack somewhere.
$40,000 total construction cost max, loaded. That is a guess.
Payload, about half ton.
Old 04-20-2005, 08:30 PM
Rep: 10 Posts: 12
SORRY DAVID.
I don't want to rain on your parade, but you have just described the
Malcolm Tennant "Great Barrier Express". It's a bit like re-inventing the wheel.
Go to Google and enter Great Barrier Express and you will see what I mean.
I have the plans, patterns and photos of this design but have never got around to building it, and now AGE has got in the way.
Over the last twenty years it has proved to be the ideal Cat for fast cruising, racing and inter-island hopping.
Cheers. Oldsailor.
Old 04-20-2005, 09:21 PM
Rep: 10 Posts: 9
great barrier express
nice boat, I have seen before in multihulls magazine. There are many boats of this type, check the list at the end, cats 26-29. Includes the barrier reef. i personally like more the corneel 26 -see fotos in:
http://www.multisailing.com/imag/238...en/page_01.htm
or perhaps the firefly http://www.firebirdcat.com/
I would centarly like to have a look at those plans.
Boat LOA BOA SA Displ Design/Mfg
Heavenly Twins 26'00 13'09 340.00 6000.00 Heavenly Cruising
Jet 26 26'00 15'05 300.00 992.00 Halacre, Douglas
Leocat 26 26'00 19'00 420.00 1700.00 Kelsall, Derek
Max 26 Micro 26'00 16'00 430.00 1128.00 Spruit Performance
My-Cat 26'00 16'03 477.00 1322.00 Oudrup/Havkat/Micro-Boats,
Pahi 26TR 26'00 12'09 300.00 1200.00 Wharram, James
Scamper 26 26'00 14'03 300.00 1984.00 Prout Catamarans
Tiki 26TR 26'00 15'01 285.00 1400.00 Wharram, James
Tikiroa (Pahi 26)TR 26'00 12'09 300.00 1500.00 Wharram, James
Trail 26TR 26'00 n/a n/a n/a Kelsall, Derek
Tri-Star Cat 26 26'00 14'00 375.00 2800.00 Horstman, Edward
Week End 8 26'00 14'03 n/a n/a Multi Difusion
Week End 27 26'00 14'03 n/a n/a Bord'Ocean
X-Kat 26 26'00 16'04 409.00 3400.00 Kelsall Catamarans
Jeffcat 26 26'01 15'09 409.00 1322.00 Lerouge, Erik
Nova Cat 26 26'01 16'05 377.00 1323.00 Nova Cat
Zoum 80R Trailer Cat 26'01 14'09 334.00 2866.00 Novation Marine
Aquilon 800 26'02 14'09 n/a 1875.00 Staneck Marine
Campacat Sport 8 26'02 13'02 360.00 1800.00 Peter Brady & Assoc.
Clyde Cats Micro 26'02 20'03 470.00 3600.00 Shuttleworth, John
Dimanche 26'02 16'03 484.00 1545.00 Langevin, Sylvestre
Edel Cat 26TR 26'02 13'01 323.00 1102.00 Langevin/Edel Cat
Kat 26 26'02 12'00 363.00 3200.00 Kelsall, Derek
Andarin 26'03 16'05 388.00 1543.00 Vollmer, Alfred
Brady 08.0 26'03 14'00 322.00 3236.00 Peter Brady & Assoc.
Catman 26 26'03 17'00 506.00 1102.00 Lerouge, Erik
Catman 27 Micro 26'03 16'05 506.00 1323.00 Lerouge/Catman SA
Cheetah 26'03 20'00 470.00 1984.00 Clyde Cats
Clyde Cats Lynx 26'03 17'03 453.00 1764.00 Shuttleworth/Clyde Cats
Corneel 26 26'03 14'09 382.00 1543.00 Joubert-Nivelt/Fount. Pajot
Falcon Supercat 26 26'03 19'05 n/a 1060.00 Southwell, Phil
Firebird 26'03 17'03 338.00 1540.00 Smith, Martyn/Modular Moulding
Format 26 26'03 16'05 431.00 2000.00 Peter, J.
Format 26 t 26'03 16'05 431.00 2400.00 Peter, J.
Lavranos 26 Micro Cat 26'03 n/a 527.00 1433.00 Lavranos, Angelo
Micro 26'03 18'05 610.00 1400.00 Lerouge, Erik
Micro Class Daysailer 26'03 16'05 463.00 1213.00 Simonis, Alexander
Micro-Multihull 8m 26'03 19'06 515.00 1653.00 Shuttleworth, John
Multi Mar 26 26'03 17'00 411.00 2400.00 Callahan, Stephen
NixeTR 26'03 17'03 480.00 1800.00 Lerouge, Erik
Pair of Twins 26'03 16'05 452.00 1875.00 Veenema, Harm
Resonance 80 26'03 15'09 465.00 1102.00 Sass, Heinz-Jürgen
Shttlewrth 8m Cr.TR 26'03 n/a n/a n/a Shuttleworth, John
Shttlewrth 8m Rac.TR 26'03 n/a n/a n/a Shuttleworth, John
Shttlewrth 8m R/CTR 26'03 n/a n/a n/a Shuttleworth, John
Sirius 26 26'03 21'02 452.00 1720.00 Chantier Naval Force 3
Spyder Mk2 26'03 18'00 446.00 1100.00 Tennant, Malcolm
Spyder 26'08 16'05 199.00 946.00 Tennant, Malcolm
Backslash 26'09 15'09 499.00 2424.00 Simpson, Roger
Stiletto 27TR 26'10 13'10 336.00 1150.00 Higgins, Bill
Stiletto GTTR 26'10 13'10 352.00 1650.00 Wormwood, Peter
Black Cat 27'00 15'00 350.00 5500.00 Manners, E.
Catalac 8m 27'00 13'06 275.00 6283.00 Lack, Tom
Get 27 27'00 n/a n/a n/a La Griffe Marine
Heavenly Twins 27 27'00 13'09 390.00 6000.00 Heavenly Cruising
Sun Burner 27 27'00 13'06 385.00 3500.00 Harris, Robert
Tini 27TR 27'00 n/a n/a n/a Kelsall, Derek
Tri-Star 27CT 27'00 21'00 552.00 1500.00 Horstman, Edward
Tri-Star 27 PC 27'00 21'00 672.00 1900.00 Horstman, Edward
Catamaran 27 27'01 18'00 313.00 1100.00 Kurt Hughes Sailing Designs
Hughes 27 27'01 18'00 365.00 1100.00 Kurt Hughes Sailing Designs
Tri-Star Cat 27 27'01 14'08 375.00 2800.00 Horstman, Edward
Surfsong 27'02 17'01 377.00 3500.00 Woods Designs
Havkat 27 C/R 27'03 14'10 360.00 2600.00 Oudrup, Lars
Havkat 27 Racer 27'03 16'06 430.00 1540.00 Oudrup, Lars
Simpson 8.3m 27'03 16'02 336.00 5225.00 Simpson, Roger
Catlife 825 27'06 14'05 146.00 1433.00 Rifflart, Marc Louis
RC-27TR 27'06 16'00 450.00 800.00 Roberts, Bill
Mariposa 27'07 11'05 323.00 2425.00 Henriks-Catanautica
Kat 28 27'08 16'08 484.00 1432.00 KL Composites
Seawind 850 27'08 18'06 479.00 4800.00 Jutson, Scott/Seawind Catamarans
Seawind 850 Resort 27'08 18'06 479.00 4800.00 Seawind Catamarans
Viva 27 27'08 15'10 600.00 1750.00 Westerly/Houghtonob
Catfly 850 27'09 14'05 460.00 4189.00 Rifflart, Marc Louis
Great Barrier Expr. 27'09 16'05 410.00 2370.00 Tennant, Malcolm
Catman F-28 27'10 17'05 387.00 1499.00 Lerouge/Catman SA
Great Barr. Exp. MkIII 27'10 17'05 n/a 2374.00 Tennant/Pilkington
Kata 28 27'10 16'06 484.00 1389.00 Lucas, Paul
Diabolo 27'11 17'04 n/a n/a CN Force 3
Kat 28 Tonic 27'11 17'04 n/a n/a KL Composites
KL 28 Standard 27'11 16'07 411.00 1500.00 KL Nautique
Wildfire 27'11 n/a n/a n/a Tennant, Malcolm
Baron Noir F-28 28'00 n/a n/a n/a Lerouge, Erik
Cat 28 28'00 16'00 420.00 3500.00 Chris White Designs
Catfisher 28 28'00 13'06 380.00 7600.00 American Catamaranob
Crocodile F-28TR 28'00 17'07 689.00 1433.00 Nielsen, Niels
Crowther 28 #228 28'00 18'00 412.00 4500.00 Crowther, Lock†
Davey-y-Joan’s 28'00 14'00 400.00 4727.00 Crowther†/Calvert
Firefly 850 28'00 18'02 489.00 2756.00 Pescott, Mark
Fisher Cat 28 28'00 n/a n/a n/a JC Plaisance
Formula 28TR 28'00 19'08 750.00 1300.00 Lerouge, Erik
Formula 28 28'00 33'00 700.00 1350.00 Shuttleworth, John
IMD 28 Folding CatTR 28'00 14'00 593.00 2700.00 Int'l Marine Dev./Morrelli & Melvin
Myers Racer 28 28'00 16'00 400.00 1300.00 Myers, Hugo†
Myers Sprint 28 28'00 14'00 400.00 1200.00 Myers, Hugo†
Nimble 28.2 28'00 15'07 443.00 4299.00 M&M Boatbuilders
Shttle. Speed Mach.TR 28'00 n/a n/a n/a Shuttleworth, John
Sophisticat 28'00 15'00 360.00 8600.00 Cope, A.N.H.
Tiki 28 Coastal 28'00 16'03 330.00 3000.00 Wharram, James
Falke 8m 28'03 14'05 366.00 3527.00 Falke Katamarane
Lagoon 28'03 21'04 n/a n/a Certa
Resonance 86 28'03 16'09 538.00 n/a Sass, Heinz-Jürgen
Tanenui 28'03 12'06 310.00 2000.00 Wharram, James
Punch 8.50 28'04 16'00 n/a n/a Chantier Naval Force 3
Format 28 28'06 18'04 484.00 3200.00 Peter, J.
Design #127 28'10 17'00 380.00 3500.00 Chris White Designs
Shockwave 29 28'10 17'00 348.00 2500.00 Crowther, Lock†
Coral Coast 29'00 15'06 420.00 2646.00 Turner, Ross/Jarcat
Harrier 29'00 19'00 484.00 3500.00 Crowther†/Harrier
Harrier 8.8m 29'00 19'00 484.00 2500.00 Bosun Boats
Imp 29 29'00 n/a n/a n/a Bimini Catamarans
Warrior 29 29'00 16'00 456.00 2000.00 Bartolone/Conser
Windspeed 29 29'00 20'00 500.00 3500.00 Crowther, Lock†
Catalac 9m 29'03 13'09 420.00 8000.00 Lack, Tom
Stiletto 30 29'04 17'10 460.00 2100.00 Wormwood, Peter
Suncat 30 29'04 18'00 510.00 5300.00 Kelsall, Derek
Suncat Sport 30TR 29'04 18'00 510.00 4000.00 Kelsall, Derek
Akka 29'06 16'00 418.00 4000.00 Woods Designs
Old 04-20-2005, 11:35 PM
DaveB DaveB is offline
Rep: 11 Posts: 128
cad file
Hi,
Neat problem... Looks like you're using Maxsurf... can you post the cad file so that we can see the shape of what you're describin'?
Cheers,
Dave
Old 04-21-2005, 09:00 AM
Peter Renew Peter Renew is offline
Hi Sail Fast t
I'm confused about your LCB and LCF. I am taking these to mean lateral centre of Bouyancy & Floatation in which case -8.67in ft & -1ft 11.3in ft don't make much sense. Please could you clarify?
For a speedster without accomodation I would have thought a length to breadth ratio of 12 plus would be more desirable.
Also are you choosing vinylester over polyester for the longer curing and therefore laminating time?
Old 04-21-2005, 10:09 AM
Rep: 10 Posts: 9
lcb and lcf
being longitudinal, distance fron the center of the profile aftwards.
never heard of lateral centers of bouyancy, I guess if the hull is simetrical centers of bouyancy would be in the centerline. Only distance to calculate is longitudinal.
Old 04-21-2005, 10:15 AM
Rep: 10 Posts: 9
cat corneel 26
check this jpg.
Old 04-21-2005, 10:26 AM
Rep: 10 Posts: 9
jpg and igs files cat 27
I attached a couple of 3d renders and a iges file
Designers agree that the semicircular section -in the stern hafl side- is the best comprmise between volume displaced and wetted area, meaning buoyancy and speed.
To design a semicircular section using hull design software, you need to specify a three point surface, align at 90 and evenly spaced, with the weights set to one except the corner one, set to 0.7071. that would take care od the underwater semicircular section. Adding more points for the freeboard, hafly towards the deck, above waterline sections, would inflect a change in the semicircular underwater section, so my question goes, is there any other way to set the points so that you would need only one surface for the hull, or do we need to split into two surfaces and then bond them, to maintain semicircular section under water and flat or convex half way in the higher freeboard?
On the other hand, small cats are very wet, and, spcecially reaching and surfing waves, they tend to pithpole, -if you ever sailed a hobbie 16 you know what i mean, -the banana shape did not help-. I wanted to introduce certain convexity and the upper sections of the bow freeboard, to reflect water when sailing and to gain bouyancy when things start getting ugly.
My catana does this very well, with its bolbous bows ans convex upper bow sections. i have surfed -reaching to get speed, down the next wave to take advantage of the negative slope and the inertia- reaching 20.4 knots -gps- and the bow goes to the limit, but not beyond. Could this feature be incorporated into a smaller symetrical design? --catanas' are asymetric-.
david
design of a fast 27 catamaran-c27-perspective-1.jpg  design of a fast 27 catamaran-c27-perspective-2.jpg  design of a fast 27 catamaran-c27-perspective-3.jpg
Old 04-21-2005, 08:13 PM
Rep: 10 Posts: 12
NICE LINES DAVID.
I think for the nasty short wave formations which I remember in sailing around the West Indies the forward sections look too fine. To prevent a very wet boat, and to reduce the possibility of pitchpoling you need more flare in the bow, or a bulb at the bottom of the stem-----or both.
Just my opinion from sailing lots of Cats in the 23' to 52' sizes.
Cheers. Oldsailor.
Old 04-22-2005, 10:03 AM
Rep: 10 Posts: 9
new hydrostatics cat 27 -for one hull-
That is why I was wondering about the LONGITUDINAL CENTER OF BOUYANCY, my first question, widening the bow sections will move the cente of bouyancy forward, and the center of gravity has to be aligned with this LCB for the boat to sit trim.
LCG longitudinal center of gravity is calculated by measuring distances from a center point and weights of every component to find the center of the weight of the whole thing, including the hull and deck, and in these case crew, since it is big percentage of its displacement. that is why more time is spent in front of the spreadsheet calculating numbers than in front of the modeling software giving a shape to this numbers. You design around numeric parameters.
Does anybody know an average for LCG in cats these type 26-28 -in % of LWL-? What about waterplane numbers?
here are the hydrostatics of the above lines -one hull-, which are modified from the first ones:
Displacement 1.13 tonne
Volume 38.82 ft^3
Immersed depth 1ft 5.85in ft
Lwl 27ft ft
Beam wl 2ft 6.23in ft
WSA 85.84 ft^2
Max cross sect area 2.27 ft^2
Waterplane area 50 ft^2
Cp 0.633
Cb 0.384
Cm 0.705
Cwp 0.735
LCB from zero pt -2.16in ft
LCF from zero pt -2ft 0.12in ft
Immersion (TPi) 0.121 tonne/in
