  #46
Old 10-20-2011, 06:15 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Originally Posted by michael pierzga View Post
As Oldsailor has pointed out...you must decide between Racer and cruiser. Performance wise, My experience says that an oceanic cruiser is optimised for reaching, a coastal cruiser is optimised for windward work. Daggerboards are not needed for an oceanic cruiser.
Not sure I agree completely.
A good ocean cruiser is optimized for best sailing performance, in general, allowing you to sail on any point efficiently.
A "racing" boat, if properly set up for single handing, easy reefing, etc... makes for the best cruiser one can buy.
Kurt Hughes was right about this place.
  #47
Old 10-20-2011, 06:24 PM
Rep: 670 Posts: 2,457
On the coast you must beat to make destination. At sea you optimize your route planning and keep the wind off your nose to make destination. Only a masochist would beat to windward for days on end.
  #48
Old 10-20-2011, 06:36 PM
Mick@itc Mick@itc is offline
Rep: 32 Posts: 74
Originally Posted by Alan.M View Post
If you're going to have saildrives, I would go with LAR keels, at least deep enough to protect the saildrive legs. Saildrive legs are too expensive and delicate to have hanging down unprotected.
You'll lose some performance though.
Hi
I'll likely be going outboards so no protection issues.
Thanks for the input.
Mick
  #49
Old 10-20-2011, 06:39 PM
Rep: 32 Posts: 74
Definitely not a Racing boat...very much as cruiser with COastL the primary and ocean the secondary use. But easy to use is primary as there will only be one and a 1/2 sailors aboard.
Mick
  #50
Old 10-20-2011, 06:40 PM
That's true, but weather can be (at times) contrary to prevailing patterns. (trade winds excepted)
Sometimes, you have to tighten it up a little bit to make a destination.
Aside from that, you only cross the ocean for a few weeks. Most of a boat's time is spent at anchor, then the remainder moving along the coast of an interesting destination. Crossing oceans is a "once in a while" situation for most cruisers.
  #51
Old 10-20-2011, 07:18 PM
Alan.M Alan.M is offline
Rep: 27 Posts: 37
Originally Posted by Mick@itc View Post
Hi
Mick
With outboards I'd go daggerboards and kick-up rudders, no question! Extreme shallow draught and beachability. Love it.
As for the coastal/ocean use - even a circumnavigator will spend time coastal cruising. Also, daggerboard boats are faster downwind too, not just upwind. Boards fully raised = less drag than LARs.
Ease of use is no issue - if you are REALLY lazy you can just leave the daggers 1/2 down. But it's really no problem adjusting them anyway - you trim sails FAR more often. Cruising, you'd adjust daggers maybe a couple of times in an average passage, often not at all.
  #52
Old 10-20-2011, 07:35 PM
rayaldridge's Avatar
Rep: 322 Posts: 581
I haven't read the whole thread, so maybe this has been mentioned, but I think that for a couple reasons, daggerboard boats are safer than boats with fixed keels.
A boat with keels is not as likely to surf sideways without taking a heavy blow, if the boards are lifted. This may be one reason Wharrams have such agood safety record. in my old Wharram, in breaking seas, the boat never took a solid blow, just sliding sideways in the broken water, very quickly.
The other reason a boat with boards is safer is that it can be taken into much shallower water to escape bad weather. Up a foot-deep mangrove creek is safer in a hurricane than anchoring in a deeper but more open anchorage. In addition, most of us will eventually try to get across a bar or other shallow area when we really shouldn't. If we have board and we hit, the board can be pulled up and the boat either will cross the bar or we'll be able to go back out. Once the keels are hard aground, the situation may become more serious.
Ray
http://slidercat.com/blog/wordpress
  #53
Old 10-21-2011, 03:03 AM
Upwind, At what wind angle would a good cruising cat, without daggerboards, sail ? With daggerboards ?
  #54
Old 10-21-2011, 06:59 AM
oldsailor7 oldsailor7 is offline
Rep: 269 Posts: 1,118
Catbuilder said. A "racing" boat, if properly set up for single handing, easy reefing, etc... makes for the best cruiser one can buy.
Amen.
I always thought the Kraken 40 made a wonderful fast cruiser for four people.
Moorings with a fin keel. a.g.turner Motorsailers 17 11-01-2010 06:24 PM
Fin keel mermont Boat Design 3 10-26-2010 01:12 PM
Fin Keel to Lifting Keel on my Columbia 28 SteveWinNH Sailboats 5 04-05-2006 05:35 AM
keel fin thickness usa2 Sailboats 14 12-05-2005 03:22 AM
Fin Keel CBrown Sailboats 7 08-10-2004 07:06 AM
