Old 09-06-2011, 11:02 AM
Hussong Hussong is offline
Previous Member
Rep: 30 Posts: 63
I think that you are right, Steve. The process of lifting a board out of its trunk by hand limits the discussion to the cruising boats that are small enough to allow such an effort. Big boats have big boards and the attachments for lifting that board become the design as much as is the foil in the water. Offering a single spare board for bigger boats requires that the lifting points be completely integrated in the design, that the fixtures not interfere with the immersed hydrodynamics and the design puts a decent skill set requirement on the person effecting the repair. I think it might be difficult to find that guy in Zanzibar.
It seems that the application requires a lot of specialized solutions compared to the typical straight board answer. It also seems that the benefit does not make a lot of sense compared to the assumed potential problems.
Old 09-06-2011, 11:11 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,603
I see no reason why a constant chord symmetrical or asymetrical curved board can't be designed to be used on either side of the boat regardless of the method of moving the board. Especially a board on a "cruising" boat.
However, based on the information provided about the Catana 59 I'm very skeptical that curved foils will provide any substantial benefit like they do on race boats. We'll see....
Interesting comparisons:
The Catana is 11% heavier than the Gunboat at light displacement and the Gunboat has a reputation for speed.
Gunboat 66 racer/cruiser
--light displacement=34,000lb
--Upwind SA- 2232 sq.ft.
--Downwind- 2583 sq.ft.
Catana 59 racer*/ cruiser
--light displacement=37,800lb
--Upwind SA- 2120 sq.ft.
--Downwind- 2583 sq. ft.
From the Catana website:
*All this has culminated in the new Catana 59. A Catana with incredibly streamlined hulls, classically elegant, and offering astounding performance. The sail plan is borrowed from racing vessels, with a short mainsail that is easy to manage and a larger foresail. Moving away from the legendary daggerboards that made the Catana shipyard's name, this catamaran is fitted with revolutionary curved daggerboards, to create a hydrofoil effect. The result is an extremely safe and comfortable boat that achieves astonishing acceleration and an extraordinary cruising speed.
yes, it is a revolution
Old 09-06-2011, 06:18 PM
oldsailor7 oldsailor7 is offline
Rep: 269 Posts: 1,118
Perhaps I'm just a retrograde old sailor. But for cruising multihulls, what is wrong with fixed low aspect ratio keels. They have many other advantages than just preventing leeway.
Old 09-06-2011, 07:13 PM
Previous Member
Rep: 30 Posts: 63
I like that you can sail in thinner water, that you can let the tide go out and sit on the keels and that you don't have to worry about a trunk getting mashed from a grounding, but don't they also have a collection of problems, as well?
Old 09-06-2011, 09:10 PM
All leeway preventing devices have their good and bad points.
I scrapped the dagger board on my Piver Nugget to get space for a fold down double berth. I replaced it with twin surface piercing boards pivoting down from sleeve boxes at the folding deck joint. They proved to be a real pain.
I subsequently removed them and fitted a Norm Cross style LAR keel.
It transformed the boat.
I armoured the leading edge and bottom of the keel with Half round metal strip and had no problems with grounding. We used to sail it straight up the pebble beach on Fox island and tie up to a tree for the night.
Open 60 using curved lifting foils Doug Lord Sailboats 11 11-22-2011 10:08 AM
Advantages/ Disadvantages of Curved Lifting Foils on Monohulls/Multihulls Doug Lord Hydrodynamics and Aerodynamics 43 10-23-2011 02:27 PM
Curved foils? andycarr9999 Multihulls 4 08-23-2011 05:51 AM
Racing Cat: Shared Lift/Curved foils Doug Lord Multihulls 2 04-21-2011 05:05 PM
A Class Cats: Curved Lifting Foils? Doug Lord Multihulls 3 01-07-2009 08:31 PM
