| CSC 30 Catamaran- the coastal passage http://www.thecoastalpassage.com/cheapcat.html Seems like a fun, cheap project. Yet google turns nothing up beyond the Coastal Passage article. Has anyone actually built one of these? Why would it only be a "smooth water" boat? |
| Every time I see those "cross beams", I nearly have a heart attack.
| Those beams made me suck a little wind there for a second too! Then I guessed that the house structure when installed probably adds a box structure by bonding to those beams. Still looks shaky? |
| That house structure looks like it is suspended between the beams for and aft, and not fixed to hulls in any serious way, look at the aft end photos, so just more load for the beams, eek ! RR |
| The first guy to finish a Slider sistership is now building one of these in Louisiana. Dean's a pretty smart guy, a diesel mechanic, so I'm thinking he's considered the beam load. They look a lot bigger than the 2X6 beams on Slider. But I think he views the boat as a Bahamas sort of vessel, rather than an ocean-crosser. I think if you look at the center pan picture, you see that there is a lip on either side of the pan, which appears to be there to bond the pan to the hulls in some way. That may covert the pan into a pretty strong stabilizing structure. Dean is an example of a guy who built an entry-level cruising multi (Slider) and liked it so much that he then went on to a larger project. This is why I think multi designers should spend more of their design time on tiny multis. The payoff isn't big upfront, but that's how you can teach people about the advantages of multihulls. |
| Design flaws aside, it it possible to build a boat for that money. That is, if you keep cost to a minimum in the interior and rigging.
__________________ Gonzo |
| beams are a box of 4x2 timber and multiple layers of ply, they actually look prety strong to me, connections to hulls and bulkheads are probly the weak spot, but that could certainly be beefed up easily for not much weight gain |
| I really didn't mean to knock the boat in a serious way, hey the guy has done it ! And I give him full credit for it ! But when looking at boats such as these you really need to have eyes wide open, those of us who have been around boats see the weak links, it's the first timers who go to see in them that worry me ! RR |
Because this would freak a lot of people out, it had beams closer to 6 x 24. |
| I guess every other catamaran is seriously overbuilt then? I see no box beam. Where are they? I see a pair of boards bolted to the top of a bulkhead where the beams would normally go.
Regards from Jeff. |
| I've written about this before I don't see how it is "cheaper" than any other 30 ft cat with the same general proportions and interior. You're going to need, say, 60 sheets of 9mm ply regardless of the design. Then the epoxy will cost the same whatever the design, so too the engine. To save money you'll buy a used engine and I suspect a used rig. Obviously you could be unwise and not use epoxy, and use the cheapest WBP ply etc and save money but end up with a throwaway boat with a 5 year life. Is that a sensible option? I certainly would not build a boat and take it to sea with plywood so obviously cheap looking as that shown in the photos If I built another of my 28ft Gypsy designs, for example, I reckon I'd could still do it for well under USD21000. After all, my prototype cost me around USD8000 to it's first sail, although that was 15 years ago now I know I'm biased, but I do think that a boat built to the design from an established designer probably has a better resale value than one designed by an amateur. And hopefully a boat like a Gypsy will have a more usefully detailed set of plans, saving build time and ultimately costs Richard Woods of Woods Designs www.sailingcatamarans.com |
| Northwest passage | BATAAN | Sailboats | 72 | 10-16-2011 08:14 AM |
| Passage makers | Bruce46 | Boat Design | 1 | 02-11-2011 06:32 AM |
| The Coastal Passage | masalai | Open Discussion: All Things Boats & Boating | 7 | 11-04-2009 01:14 AM |
| New Edition of The Coastal Passage out now | tcpbob | Press Releases | 2 | 02-15-2008 01:24 AM |
| Passage makers | notatrace | Boatbuilding | 4 | 10-01-2007 03:47 AM |
