#106
| Thanks for the heads up Cat. epoxy first, then ply, got it. ![]()
__________________ I am skeptical of the deniers diatribe |
#107
| Kite Sailing Quote:
Here is a very interesting video of a 30' tri Sailing a kite rig! You aren't far off on your comment! http://youtu.be/4mFXxroPmqg Aloha |
#108
#109
| We can build flat panels. I have had several discussions with Richard about supplying his clients with panels for a kit. |
#110
#111
| I'm pretty sure I included a link, its a bulk price, wholesale, I've got a contractors license, and no its not Chinese, I'm really leery of any Chinese products.
#112
#113
| Hi Dave, not sure were I left that link but I'll find it, I know I wrote it down somewhere but I'd think any of the bulk distributors would have it in that range if your buying the three pallets worth I had spec'd out for that cat design I'm working on. I'll stumble across it again I'm sure and I'll be sure to send it along. Cheers B
#114
| Picnic Weekender Powercat This is a bit bigger vessel than brought up under the original posting, BUT it is one that would lend itselt to 'flat panel' construction. She is built with saturated wood epoxy method. I took these original photos back in 2007-8 down near Pattaya, Thailand. Just a week ago March 2012, I had occassion to revist that marina, and WOW I found the same vessel still docked there. She is doing a steady day charter business. I also made contact the crew and got the owners info. He is just having a 2'nd and 3rd one built. Weekender/Picnic PowerCat I'll post some more photos I just recently took, as soon as I have time to get them off my camera. I'll also have some thinks to say about 'flat panel / composite panel' construction materials and technics that I've been looking at for another client, and looked at there in Thailand. Meanwhile have a look at this discussion http://www.cruisersforum.com/forums/f48/are-cats-made-from-duflex-panel-kits-strong-22948.html" Are Cats Made from Duflex Panel Kits Strong ? |
#115
...by private email at: runningtideyachts@gmail.com Brian |
#116
boater who decided to try sailing, wanted something a bit different and decided a harry would fit the bill. He bought the plans for a strip planked 15m, stretched it to 18, built a table, taught himself infusion and built it from flat Polycore/glass panels. Not the prettiest boat in the world, and not completed yet (90% done, 90% to go. ;-)) but he is having a great time, and reckons it has cost less than a pretty boat half it's size. Polycore is (was, I have not checked for a while) much cheaper than foam. Used with vinylester resin, the panels are low cost and quicker than scarphing ply. Rather than make a mould quality table, it is easier to make it from formica faced mdf with flash tape over the joins and spray sandable gel coat on as the first coat. This is easily sanded to prepare it for top coat. To really save time fairing, ensure that all joins are rebated in the infusion. It is much easier to fill and fair a hollow than a hill. There is a video of the boat sailing at http://youtu.be/LE7jw-yjTmQ and some photos at http://au.groups.yahoo.com/group/har...10865/pic/list rob |
#117
#118
The original harrys http://www.youtube.com/watch?v=8chR6DAFjGA had fairly blunt bows, as it was thought that they would sail nose down. They also throw up a bit of water, although none of the owners feel it is enough of a problem to do anything about it. In fact, most of them like it. As nose down has not been a problem, on the latest boats the bows are sharper. In strong winds, big waves, the boats are dry. As the speed gets up, regardless of waves and wind, the lee bow throws up increasing amounts of water, but little or none of it gets to the bridge deck, and none gets to the steering wheel. The windward bows are also quite blunt and at speed water tends to climb the sides of the boat, run across the deck and over the cockpit cover. http://www.youtube.com/watch?v=5pOsgqrO59A This is very irritating, but is easily fixed with a low ridge around the edge. The second video also shows a lot of water coming off the external rudders. This reduces significantly when the rudder housings are faired, and is almost non existent on the new boats where the rudders are on the beams, rather than alongside the hulls. rob |
| Northwest passage | BATAAN | Sailboats | 72 | 10-16-2011 08:14 AM |
| Passage makers | Bruce46 | Boat Design | 1 | 02-11-2011 06:32 AM |
| The Coastal Passage | masalai | Open Discussion: All Things Boats & Boating | 7 | 11-04-2009 01:14 AM |
| New Edition of The Coastal Passage out now | tcpbob | Press Releases | 2 | 02-15-2008 01:24 AM |
| Passage makers | notatrace | Boatbuilding | 4 | 10-01-2007 03:47 AM |
