converting moments of inertia into metric
Discussion in 'Multihulls' started by Corley, Dec 18, 2014.
  1. Corley
    Likes: 196, Points: 63, Legacy Rep: 826
    Corley epoxy coated
    I'm looking for a rotating mast section for my F40 project and have been given a moment of inertia value for the two axis in imperial units just wondering if anyone can give me the heads up on how to convert to a metric measure? These are the values I've been given least axis 27 in^4 and other 63 in^4.
  2. NavalSArtichoke
    Likes: 9, Points: 0, Legacy Rep: 83
    NavalSArtichoke Senior Member
    Well, which ones? m^4, cm^4, or mm^4 have all been used at one time or another.
  3. TANSL
    Likes: 708, Points: 123, Legacy Rep: 300
    TANSL Senior Member
    1 inch = 2.54 cm
    so
    (1 inch)^4 = (2.54 cm)^4 = (2.54)^4 cm^4 = 41.62314256 cm^4
    can that help?
  4. rcnesneg
    Likes: 6, Points: 0, Legacy Rep: 58
    rcnesneg Senior Member
    I would try Unit Analysis, a cool trick where you convert from one unit to another.
    Ie: 1 inch (2.54 cm/1 inch) = 2.54 cm. The inches cancel out, you multiply by everything on top, and divide by everything on the bottom.
    Another example:
    52 mph = 52 miles/hr (5280 ft/1 mile)(1 meter/3.28084 ft)(1 hr/3600 s) = 23.2460792561 meters per second.
    If you have squared units, or to the fourth, or whatever, just use that conversion.
    Ie: (1 inch)^4/(2.54 cm)^4 or (1/41.6231), etc.
    The easy way: Use this thing: http://www.unitconversion.org/unit_converter/moment-of-inertia.html
  5. Corley
    Corley epoxy coated
  6. Ad Hoc
    Likes: 1,688, Points: 113, Legacy Rep: 2488
    Ad Hoc Naval Architect
    I'm curious. Do you regularly quote values down to 9 decimal places in plate thickness for example, or the scantling of a transverse frame when designing a boat?
  7. gonzo
    Likes: 1,726, Points: 123, Legacy Rep: 2031
    gonzo Senior Member
  8. TANSL
    TANSL Senior Member
    No, it would be nonsense, I only use 8 decimal places. See my post.
  9. gonzo
    gonzo Senior Member
    Garbage in- garbage out. Pay attention to the sig figures.
