| Converting Keels to Dagger Boards As you all know, my Kurt Hughes 45 build failed. Life (and boating) must go on. ![]() I have been looking at catamarans in the $200K-$300K range that I can use for my chartering and they are all poorly designed. I have not found any that have 4 staterooms and 4 heads that also can sail. My question surrounds an idea: Could I take something like a Fountaine Pajot and remove the keels, cutting a hole and putting in proper dagger boards (with airfoil shape) for windward performance? Has anyone done this? As a side question, what is the best performing catamaran with 4 staterooms and 4 heads in the $200K -$300K range?
| Is life so difficult, that you can't live without a head within a 15' circle, of each step you might take? |
| Sure you could do it but most of them have incompatible interior arrangements....so you get into a big mess changing everything...... http://www.yachtworld.com/core/listi..._id=75840&url= http://www.yachtworld.com/boats/1999...huket/Thailand http://www.yachtworld.com/core/listi..._id=53169&url= This one...the Outremer 50 Light will be the best sailing boat.... http://www.yachtworld.com/core/listi..._id=76793&url= http://www.yachtworld.com/core/listi..._id=75043&url= http://www.yachtworld.com/core/listi...g_id=2065&url=
Yes, my bladder leaks like a sieve and I eat Taco Bell and drink Keystone Light beer. ha ha ha Kidding, of course. If you go back and read the opening post, I think I mentioned it was for charter?
| Good point about the interior difficulties. Given the heads are probably right in the spot you need the board to be, this could present a lot of problems in the modification. I'll take a look through the links and at the Outremer. Thanks. ![]() Quote:
| load change going from straight dagger boards to curved? | themanshed | Boat Design | 2 | 04-21-2010 09:30 PM |
| Catamarans with dagger boards | elnido | Multihulls | 3 | 01-15-2009 03:06 PM |
| Dagger board and rudder design | peterking182 | Boat Design | 2 | 12-12-2007 02:47 AM |
| Adding dagger boards to polyethylene amas? | llamalookout | Multihulls | 3 | 06-22-2007 01:57 AM |
| Catamaran Dagger Boards | Inquisitor | Boat Design | 10 | 11-18-2005 09:41 PM |
