#31
| Darn it I figured crew CG at 4 feet out because a male center of gravity is above the waist. Average female CG would be around 3 feet. |
#32
| Everyone, I appreciate the thoughts. Bruce, what isthe H-18 section, approximately? |
#33
| H-18 section Ray, I just measured one so these are exact. The extrusion is exactly 3"x5", 3/32" walls with thickened areas in the sides and front. It is a "fat" teardrop profile and 28' overall with 20' to the jib eye. The diamonds are 1/8" and the shrouds are 3/16, all swaged. H-18s, even with the "magnum" 3' rack extentions plus traps, hardly ever broke anything. Heavy but durable. B |
#34
) ... Probably for a basketball player. I had in mind 3.5' with the fulcrum @ midpoint on the lower hull, so 7.5'... Total being 11...Ray, you're welcome. Good luck with the build. |
#35
| I think my D23 that uses an H18 rig has 1/8" wires, and 3/16" sea stays as designed. Beam is 18.5 feet. The rig fell down last year at anchor, when a jet ski went by. Some nut wasn't tight, or some nut didn't tighten. No damage to the rig or boat. Anyone have a rule of thumb on tensioning diamond wires, as a basic, don't-blow-up setting, not to gain performance? I had to take the DWs appart to store the spar last year, and don't have any fancy rigging tension measuring device? http://www.youtube.com/watch?v=BnLmKXY-FCg |
| beach cat | Natsu | Multihulls | 17 | 04-14-2010 05:32 PM |
| New Rig for Old Cruising cat... | DirkP | Multihulls | 10 | 02-20-2010 11:12 PM |
| converting an old soling to a gaff rig | bda6 | Sailboats | 17 | 10-15-2007 08:12 PM |
| Rig handling: Cat Ketch, Cat Schooner, Sloop, Cutter | Seafarer24 | Sailboats | 8 | 05-30-2006 10:06 AM |
| Twin rig beach cat? | Matt Lingley | Sailboats | 1 | 04-04-2004 11:02 AM |
