Old 02-26-2012, 09:05 PM
Jeremyh Jeremyh is offline
Rep: 15 Posts: 12
A class catamaran build in Sarasota, fl
Sam Armington, Gary Armington, Felix Herrin, and Jeremy Herrin began building a class catamarans designed by O.H. Rodgers this weekend. Gary Armington and Felix Herrin have experience in building boats. Jeremy Herrin and Sam Armington are the sailors who recently won the U.S. Youth Multihull Championship and are going to ISAF Youth worlds this summer in Ireland. Follow our build here http://www.ah-sailing.blogspot.com/
Old 02-26-2012, 09:22 PM
Doug Lord's Avatar
Flight Ready
Rep: 1101 Posts: 7,445
A Class
Congratulations! Is this the same OH Rodgers that designed quite a few monohulls including the Kiwi 35?
Will you use curved daggerboard foils? Rudder "T" or "L" foils? Will you use a standard wing mast or do your own?
All carbon hulls, mast and beams? Best of luck!
UPDATE-found some answers:
"The a class catamaran is the fastest, single-handed catamaran today, built entirely of an ultra strong, light weight carbon fiber-epoxy construction. We were interested in building a cats and met O.H. Rodgers of David Island Yacht Club in November. He designed, built, and sailed his a class catamaran as seen here. The boat is of a modern design and features a modern wave piercing bow section, high volume sterns, low rocker, and curved foils. From the tooling of O.H. Rodgers, our boats will be built."
yes, it is a Revolution
Old 02-26-2012, 10:10 PM
Rep: 15 Posts: 12
Thanks! Yes, that is him. We will use curved daggerboards, and normal rudders. We will try to find a used production wing mast in the U.S. most likely a Hall mast, possibly a Fiberfoam. If you knew anyone who could help us with that it would be great. The boat is made of 5.7oz 2x2 twill Carbon skin, 1/4" divinycell h80 core, inner skin, then reinforcements. We are designing some different, curved beams, also carbon.
Old 02-26-2012, 10:23 PM
Doug Lord's Avatar
Flight Ready
E-mail me(click on my name and go to my profile) and I'll give you a guys name here in FL that might be able to help with a used mast. Also, Matt McDonald at Falcon Marine(Port Canaveral) is doing the tooling for a new wing mast-expensive but first class.
Old 02-26-2012, 10:55 PM
HollaStern HollaStern is offline
Rep: 10 Posts: 2
Are plans for this platform available? Or any well designed A class? I have been wanting to build a boat that I can race competitively so it seams like the A-Cat is the obvious choice. I want to use a similar method to the LR4 by Lindahl but have only been able to find designs meant for ply construction. Traditionally I think that a lot of home built A-cats have been designed by the builder but I am no designer. I would hate to waste all the time building and high quality materials on a boat that will start out behind.
Old 02-27-2012, 11:29 AM
spidennis's Avatar
spidennis spidennis is offline
Rep: 124 Posts: 502
HollaStern, first post? welcome to the boatdesign forums! and yes, like you, I'd love to have an A class set of plans! In another thread I got going I'm also searching for F16 plans and think I found them!
Old 03-04-2012, 04:55 PM
Rep: 15 Posts: 12
Today we built the outside of the port hull check it out at
Old 03-04-2012, 05:01 PM
Doug Lord's Avatar
Flight Ready
A Cat
Good work-keep it up. What is the nominal hull lamination?
Old 03-04-2012, 05:15 PM
Rep: 15 Posts: 12
The hull lamination goes: 5.7 oz carbon, h80 divinycell, 5.7 oz carbon, ring frames and extra core in between frames for trapeze support
Old 03-26-2012, 06:25 PM
Doug Lord's Avatar
Flight Ready
How you guys coming along?
Old 03-26-2012, 08:12 PM
Rep: 15 Posts: 12
good we are currently building a plug for the main beam, Gary and Sam are heat forming there foam so they can lay up their boat, and the bulkheads in my boat are almost ready to be glued in
Old 03-30-2012, 11:09 PM
Rep: 15 Posts: 12
more updates, check it out and follow at http://www.ah-sailing.blogspot.com/
Old 04-20-2012, 09:24 PM
Rep: 15 Posts: 12
More updates, Bulkheads going in, parts for second boat finishing. http://www.ah-sailing.blogspot.com/
Old 04-20-2012, 09:30 PM
Doug Lord's Avatar
Flight Ready
Jeremyh, looks like the hull bottoms are really flat starting at the bow-am I seeing that right? Keep up the great work and good luck!
Old 04-20-2012, 10:43 PM
Rep: 15 Posts: 12
The aft sections of the boat are flatter and the front have a more round profile and thanks, keep following
20' Tornado Class catamaran hulls.. Morse Marketplace 3 07-17-2012 01:52 PM
Formula 40 catamaran class rules Alik Multihulls 22 01-10-2012 10:10 PM
DNA A Class Catamaran Doug Lord Multihulls 2 11-24-2011 10:34 AM
Wild Thing Modeling A Class Catamaran GONCAT Multihulls 4 04-24-2009 08:33 AM
Catamaran design for Charter purposes (Class Project) TS1 Boat Design 1 02-04-2008 11:00 PM
