Old 03-08-2010, 01:55 PM
Palmer Palmer is offline
Rep: 10 Posts: 53
I think everyone knew you were talking about ventilation when you said cavitation. Don't take it hard if your terminology is corrected. If your engines are up against the transom then the anti-ventilation plates should probably be about even with the keels. If they're offset from the transom then raise them about an inch for each foot of offset. There may be other factors as was mentioned so it would probably be best to use the middle mounting holes so you can adjust the height if you need to.
Cavitation and Ventilation are different things and one doesn't cause the other.
Old 03-08-2010, 02:03 PM
bax bax is offline
Rep: 10 Posts: 21
Palmer & Gonzo,
Thanks for the input. You're right, I just thought we were getting side tracked a bit. Never pays to be thin skinned!
Old 03-09-2010, 01:31 PM
Rep: 1493 Posts: 7,447
Thin skined will kill you in this forum
Cavitation Plate Position 290 Duoprop dmcc Sterndrives 2 12-02-2008 11:37 PM
cavitation plate and keel tuantom Powerboats 3 09-01-2007 01:24 PM
Advice please on best depth for cavitation plate on Carolina Skiff Bigdaddy Outboards 3 04-25-2006 09:32 AM
Cavitation ( under certain conditions ) Rett Propulsion 2 12-14-2005 01:18 PM
cavitation Powerboats 12 09-09-2002 05:25 PM
