| Catamaran whit 2 Jet Ski pumps and 2 air cold diesel at 26 Hp? Catamaran whit 2 Jet Ski pumps and 2 air cold diesel at 26 Hp? Hi I’m having started to think how to build a trainable catamaran for easy handling. Have start to think that I will use 2 air cold diesel engines’ at 26 hp connected to a jet ski pump each instead of ordinary propellers. Is it some big disadvantage to do so or any odder wrong thinking of me? |
| Disadvantage would be lower efficiency over a prop, especially at relatively low speeds and attaching two engines to a single jet pump sounds like a pain . Outboards give more internal room and are a lot less difficult to install. |
| I figure a catamaran would have one engine and one pump in each hull. How big is the thing? If you're talking about a six-metre, half-tonne runabout, you may be on to something interesting. But remember that a jet ski pump is tuned for high velocity and relatively low flow at very high RPM, when compared to a normal jet pump or a propeller. That translates to a significant loss of efficiency at lower power levels.
| My planing was one engine and pump in ecth hull. And it could be around 5 meters long and 2.50 whith. A out bord enging is not a solution for me, have to be a fixt instalation what its well sound protekted. |
| just pull a couple of old jetskis apart and bed the engines/jets into your cat, only engineering hasslre then is getting your jets steering right sean |
| What diesels are you planning on using? They could be a bit heavy for a relative small boat. How do you want to steer? Rudders or jet drives? Regards Alan |
| I had plan to youde KIPOR DIESEL 2 cylinder whit a wighit at 64 kg The stering seams to be esyest whit the water jets. |
| I'm considering a similar setup for my sailing cat - using two 4-cyl petrol jetski motors instead of outboards. Only drawback is the reverse is not very strong, but then there is nothing the fishing line can tangle on ![]()
| If you're considering diesel for fuel economy I guess it depends on how you want to use the cat. The 4 cyl motors has fuel injection etc and if you keep the revs down they do quite well on fuel.
| If Im not wrong most jet ski´s have around 6500 rpm at max and the diesel 3400 rpm so I nead a gear box betwin to get the revs up. The quistion is then if the engine are strong enuf foor that task? |
| 2 jet ski´s = 1 catamaran? | RSALVAREZ | Projects & Proposals | 3 | 04-23-2008 11:26 AM |
| The Jet (air) Engine | kach22i | Propulsion | 0 | 11-30-2007 01:41 PM |
| Ducati IS-11 air cooled diesel | martinwill | Diesel Engines | 0 | 03-11-2007 05:15 AM |
| Jet Ski Jon Boat | 2001aggieusmc | Boat Design | 1 | 10-18-2006 03:08 AM |
| Ski jet in boat | Powerboats | 10 | 08-12-2002 08:32 AM | |
